ผู้เขียน หัวข้อ: *** ปีกนก E46 แบบพิเศษ ***  (อ่าน 2548 ครั้ง)
« เมื่อ: กรกฎาคม 04, 2013, 16:35:23 »
Home  Wisefab - BMW Steering Lock / Angle Kit
Details
This kit replaces these standard parts on your BMW:
Lower arms
Tie rods
Tie rod ends
Suspension top mounts
The knuckle part is fitted in addition to your original knuckle
Key features of the Wisefab kit
Offering over 60 degrees of steering lock, the near zero ackerman Wisefab BMW kit provides more steering angle than you will ever need, without hitting the lower arms like you would on a normal high steering angle BMW set up.
Built in lock stops - Steering wobble at high steering angle can cause unwanted stress on components, so the Wisefab has a positive lock stop allowing you to chuck the car lock to lock with confidence.
Roll Centre Correction: The kit corrects roll centre by approx 35mm, keeping the correct lower arm angle on lowered cars, and compensating for the removal of the front anti roll bar.
Improved Camber Control - This helps keep the tyres contact patch as the suspension compresses, and when the car is in opposite lock. When drifting ( on opposite lock) often the leading wheel rolls into positive camber and looses it's contact patch on traditional drift car setups. The Wisefab kit has compensated for this..
Improved Steering Jacking - Steering Jacking is where where one side of the car lifts as steering lock is applied. On cars with a large amount of steering angle this can sometimes feel like you are fighting with the weight of the car when steering. The Wisefab kit has been designed to reduce steering jacking.
Steering speed is improved, and in spite of the castor and king pin inclination changes, the kit still self centres correctly.
Notes
Pictures show E46 FD Legal Kit. Other kits may differ
Motorsports use only -NOT FOR ROAD USE!
This kit changes the track width of the front suspension dramatically, It will require higher offset narrower wheels than you can fit using normal hubs.
Wider front wings (fenders) may be required.
IT is recommended that you don't use a tyre with a bigger diameter than 620mm (235/40/17 for example)
The Wisefab BMW steering lock kit, has been used with great success on a huge amount of competition cars. If you want. If you want the most insane steering angle on the planet, then this is the kit for you!
pong e46
  • กระทู้: 108
Re: *** ปีกนก E46 แบบพิเศษ ***
« ตอบกลับ #1 เมื่อ: กรกฎาคม 04, 2013, 21:32:42 »
สวยครับเห็นแล้วอยากได้เลย.
« ตอบกลับ #2 เมื่อ: กรกฎาคม 04, 2013, 23:52:41 »
เทพมาก ;)
Max-sticker
  • กระทู้: 290
  • MaxStickeR Car Wrap
« ตอบกลับ #3 เมื่อ: กรกฎาคม 05, 2013, 00:14:42 »
ติดตั้งแล้วจะเป้นไงอะครับ
                   088-685-1649 แม๊กคราบ มีนบุรี
« ตอบกลับ #4 เมื่อ: กรกฎาคม 05, 2013, 08:33:47 »
"Motorsports use only -NOT FOR ROAD USE!
ใช้กับสนามแข่งเท่านั้น ไม่เหมาะกับการใช้งานทั่วไป
ชุดนี้จะเปลี่ยนความกว้างของช่วงล่างด้านหน้าอย่างมาก และมันจะต้องการใช้ล้อที่มีออฟเซ็ทมากขึ้นหน้าแคบลงกว่าที่คุณจะใช้บนดุมล้อเดิม
แก้ข้างแบบกว้างอาจจะจำเป็นต้องใช้
IT is recommended that you don't use a tyre with a bigger diameter than 620mm (235/40/17 for example)"
และแนะนำว่าห้ามคุณใช้ยางที่เส้นผ่าศูนย์กลางใหญ่กว่า 620 mm(ยกตัวอย่าง 235/40/17)
ชุดนี้ห้ามวิ่งถนนเมืองไทยครับ ตกหลุมตื้น ๆ ปีกนกก็หักแล้ว
« ตอบกลับ #5 เมื่อ: กรกฎาคม 06, 2013, 13:58:01 »
จบเลย โดยเฉพาะประโยคสุดท้าย :'(
« ตอบกลับ #6 เมื่อ: กรกฎาคม 06, 2013, 19:56:42 »
ถ้าใช้ในสนามแข่งจริง ไม่น่าหักง่ายๆนะครับ
แต่ใช้ในสนามแข่งนี่ ราคาคงไม่ธรรมดาแน่
« ตอบกลับ #7 เมื่อ: กรกฎาคม 06, 2013, 22:03:21 »
ขอบคุณที่ เข้าใจ ครับ  ;)
« ตอบกลับ #8 เมื่อ: กรกฎาคม 07, 2013, 00:39:02 »
หักง่ายจริงครับพี่ ลองดูคลิปเวลารถแข่งในสนามเกิดการกระแทกกันสิครับ ล้อจะหลุดออกนอกตัวรถก่อนเพื่อนเลยครับ ถ้าไม่มีการกระแทก มันจะทำให้รถซงตัวดีมากถึงมากที่สุด แต่ถ้ามีการกระแทกเมื่อไหร คือจบ :-*
« ตอบกลับ #9 เมื่อ: กรกฎาคม 07, 2013, 01:22:25 »
ปีก M ก็น่าพอแล้วนะครับพี่
