ผู้เขียน หัวข้อ: ฺBMW M235i น่าจะเห็นในบ้านเราเร็วๆนี้  (อ่าน 3201 ครั้ง)
krissanova
  • Golf - Kris - Krissanova
  • กระทู้: 486
  • กอล์ฟ
« เมื่อ: พฤษภาคม 28, 2014, 12:30:40 »
A shorthand for power and speed, BMW’s “M” is a scarlet letter, a talisman for tire-smoking sin. The consonant was most recently applied to the new 2 Series compact sport coupe, specifically to its M235i varietal.
Our Melbourne Red Metallic test car carries a 320-horsepower twin-turbo in-line six-cylinder engine whose sweet power delivery is complemented by the red rocket’s blare. The sound and fury reconcile at redline, as the M235i vaults to 60mph in just 4.8 seconds, the same time as the 1 Series M coupe.
The M235i’s arrival was a red-letter day to fans of the 1 M, the hot version of the previous 1 Series coupe. BMW is rumoured to be readying an M2 for 2015, but for now, the M235i boasts a near-identical power-to-weight ratio as the 1 M, and virtually reproduces that car’s performance. The Bimmer faithful will note that the M235i is 15hp short of the 1 M and carries a dog-kibble bag’s worth of extra mass, but its ZF eight-speed automatic transmission’s quick gear changes (the 1 M was only available with a six-speed manual transmission) is the great equaliser here.
Of course, hardcore driving enthusiasts will want the do-it-yourself standard six-speed manual transmission, but the eight-speed auto provides all the paddle-shifted tactile control they could want, with added low-speed smoothness and refinement. Recall that both the Corvette Stingray and Jaguar F-type have opted for automatics rather than dual-clutch setups.
Still, an auto 'box feels somewhat out of step with the M235i’s idealised role as the stripped-down, minimalistic keeper of BMW’s gearhead flame. It isn’t the biggest betrayer of that image, however. The car is also saddled with BMW’s iDrive infotainment interface – a notoriously fickle and unintuitive piece of technology – even though the tested model lacked a navigation system, which seemed to make the entire iDrive system feel all the more needlessly complex.
As ever, there is also the matter of BMW’s insistence on a keyless ignition button that requires two presses to turn the car off. And do make certain to depress the button for the second time with your foot off the brake – that is, unless you want the engine to restart. Other stubborn product strategies are well represented, too, such as a turn-signal stalk and automatic shifter that return to centre when used, rather than staying in their logical indicated position.
These unfortunate latter-day brand sins distract from a fundamentally spectacular machine. The 235i is a wedge-shaped ruby slipper of a car, its flanks dripping over the underlying running gear. What BMW is losing in terms of ergonomic proficiency it is making up in styling. It is not easy to meet pedestrian protection standards without employing the blunt, ice-breaker prows seen on other recent Bimmers, a noteworthy accomplishment.
Some of the newfound fluidity is owed to a 4.3in increase in length, a change that makes the car’s virtually identical weight to the 1 Series M all the more impressive. Another contributor is the M235i’s lowered stance; ride height drops by nearly an inch compared to the base 228i.
The suspension has active shock absorbers whose settings are controlled by the Driving Experience Control switch on the console. This test car spent a lot of time in Sport, which imparted pleasant steering heft and a stiffened but supple ride, though the throttle was rendered overly sensitive.
The Comfort setting is, by definition, the most livable, delivering linear throttle response and a softened ride, while Eco Pro helps the car sip gas through tricks like shifting the electronic transmission into neutral when coasting. Such measures are intended to boost fuel economy, but they can leave the car feeling like it lags the driver’s input by half a beat.
A pleasantly invisible feature is the M235i’s variable electric power steering. Early iterations of variable steering were intrusive and unpredictable, but the M235i just goes where the driver intended, and it goes quickly and accurately. Variable steering’s redemption is further complemented by thoughtfully tuned electric power steering, which provides ample steering feel.
It is possible that a forthcoming M2 will be even better, but as most sinners will learn, today’s M235i delivers more than enough deviant thrills.
Re: ฺBMW M235i น่าจะเห็นในบ้านเราเร็วๆนี้
« ตอบกลับ #1 เมื่อ: พฤษภาคม 28, 2014, 13:11:30 »
มองผ่าน ๆ.... ท้าย E46 น่าจะสวยกว่านะ ครับ  ^-^   ^-^
« แก้ไขครั้งสุดท้าย: มิถุนายน 03, 2014, 15:40:19 โดย JBR1992 »
« ตอบกลับ #2 เมื่อ: พฤษภาคม 28, 2014, 13:49:40 »
มีแต่ราคา 220i ราคา BMW Series 2 บีเอ็มดับเบิลยู ซีรีย์ 2 (2014-2015)
ราคา BMW 220i Sport 2,799,000 บาท
ราคา BMW 220i M Sport 2,949,000 บาท
itongx
  • กระทู้: 689
  • No one is perfect!!
« ตอบกลับ #3 เมื่อ: พฤษภาคม 28, 2014, 14:17:05 »
F80 กับ F82 นี่น่าสนใจเหมือนกันนะครับ  ::dance:: ::dance:: ::dance:: ::dance:: ::dance::
"ต้อง ครับ"
krissanova
  • กระทู้: 486
  • กอล์ฟ
« ตอบกลับ #4 เมื่อ: พฤษภาคม 28, 2014, 15:35:24 »
รุ่นที่ผมลงเป็น 235i 6 สูบ twin-turbo ครับ
ในบ้านเรามีแต่ 220i
« ตอบกลับ #5 เมื่อ: พฤษภาคม 28, 2014, 16:55:40 »
M235i ตปท เค้ารีวิว ชื่นชมไว้เยอะ บอกเป็นรถที่น่าขับมากๆรุ่นหนึ่ง ดีกว่า M1
แต่มันไม่ใช่ M car นะ แค่แต่งM performace และมีม้ามากกว่าตัวธรรมดาอยู่สัก20ตัว
เครื่อง6สูบแถวเรียง 3000cc. Turbo
แรงม้า 320HP แรงบิด 330lb-ft
8 speed
0-100ใน 4.4วิ
ดูรีวิว ไม่อนุญาตให้คุณมองเห็นลิงค์ สมัครสมาชิก หรือ ล็อกอิน
  ::2thmb:: ::2thmb:: ::2thmb::
« แก้ไขครั้งสุดท้าย: พฤษภาคม 28, 2014, 16:57:29 โดย Chris »
Poy m3
  • กระทู้: 33
« ตอบกลับ #6 เมื่อ: มิถุนายน 01, 2014, 15:16:30 »
« ตอบกลับ #7 เมื่อ: มิถุนายน 01, 2014, 16:57:34 »
ถ้าเอาราคาตัวที่ขายในไทย ราคานั้นผมว่า f30. 328 น่าสนใจกว่าครับ
Pooh555
  • กระทู้: 327
  • Happy Day...
« ตอบกลับ #8 เมื่อ: มิถุนายน 01, 2014, 22:02:09 »
ดูราคาแต่ละรุ่นแล้วนี่ราคาแรงดีจริงๆเลย  ::2thmb::
