ผู้เขียน หัวข้อ: รายละเอียด รหัสโค๊ตต่างๆ ครับผม สำหรับ DIS  (อ่าน 6299 ครั้ง)
DME M1.1, M1.2 and M1.3
• 1 DME Fault
• 3 Fuel Pump Relay EKP
• 4 Idle Speed Controller
• 5 EVAP Canister Valve
• 6 Air Flow Sensor
• 7 Air Flow Sensor
• 8 "CHECK ENGINE" Light
• 10 Lambda Regulation
• 12 Lambda Sensor
• 15 "CHECK ENGINE" Light Failure
• 16 Injectors Cyl 1,3,5
• 17 Injectors Cyl 2,4,6
• 22 Idle Speed Controller
• 23 Lambda Sensor Heating, or Aux Air Pump Relay
• 28 Lambda Sensor
• 29 Vehicle Speed Sensor (VSS)
• 32 Injectors 2/4
• 33 Solenoid Valve Kickdown (Automatic Transmission)
• 37 System Voltage
• 38 ASC/DWA (EML Vehicles)
• 40 AirCon Compressor
• 43 Idle Speed Setting - CO Adjustor
• 44 Inlet Air Temperature Sensor
• 45 Coolant Temperature Sensor
• 50 Engine Torque Regulation (EML)
• 51 Ignition Angle Regulation (EML)
• 52 Idle Speed Switch
• 53 Wide Open Throttle (WOT) Switch
• 54 Torque Converter Lockup Clutch
• 55 Ignition System
• 100 DME Control Unit Final Stage
• 101 DME Plausibility - Engine Inoperable
• 252 DME Control Unit
• 255 DME Control Unit -Internal Error
DME M1.7, M1.7.1, M1.7.2, M3.1 and M3.3
• 1 Fuel Pump Relay or RPM Signal
• 2 Idle-Speed Controller
• 3 Injectors (4cyl-1,3; 6/8cyl-1,5; 12cyl 2,4,6 or 8,10,12)
• 4 Injectors (DME 3.3.1 Cyl 4,6)
• 5 Injectors (DME 3.3.1 Cyl 3,5)
• 6 Injectors- General
• 7 VANOS Relay or Injector cyl6 (DME 1.7.2)
• 8 "CHECK ENGINE" Light Failure
• 12 TPS or Lambda Sensor (M3.3.1)
• 13 Lambda Probe
• 15 Knock Sensor 1 (DME 1.7/DME 3.1)or Ignition Fault (DME 1.7.2)
• 16 Ignition System or Cam/Crank Position Sensor
• 17 Cam Position Sensor
• 18 DISA Valve (DME 1.7.2)
• 19 Electric Fan Output Stage
• 20 Cruise Control
• 22 Ignition Fault Cyl 7
• 23 Ignition Fault Cyl 4 or 6
• 24 Ignition Fault Cyl 4 or 6
• 25 Ignition Fault Cyl 1 or 5
• 26 Voltage Supply
• 29 Idle Speed Controller
• 31 Injector on Cyl 3 or 5
• 32 Injectors (4cyl 2/4; 6cyl 2/6; 8cyl 8/2; 12cyl 1,3,5 or 7,9,11)
• 33 Injector on Cyl 1 or 3
• 35 Injector on Cyl 2
• 36 EVAP Canister Valve
• 37 Lambda Heater Relay
• 38 Lambda Heater Relay
• 41 Air Flow Sensor
• 42 Speed Signal or Knock Sensor 2 (DME 1.7.x or 3.3.1)
• 46 Electric Fan
• 48 AirCon Compressor Shut Off Relay
• 49 Injector on Cyl 2
• 50 Ignition Fault on Cyl 1 or 3
• 51 Ignition Fault on Cyl 2 or 8
• 52 Ignition Fault on Cyl 5 or 3
• 54 Voltage Supply
• 55 Ignition (Final Stage)
• 62 Signal (EML)
• 63 Torque Converter Lockup Clutch
• 64 EGS/DME Connection Error
• 65 AirCon Compressor
• 66 Theft Warning System (DWA)
• 67 Crank Position Sensor or Knock Sensor 4 (DME 3.3)
• 68 Knock Sensor 3
• 69 Knock Sensor 2
• 70 Lambda Sensor (DME 1.7.x or 3.1) or Knock Sensor 1
• 73 Vehicle Speed Signal (VSS) or TPS
• 76 Idle Speed Setting - CO Adjustor
• 77 Intake Air Temperature Sensor
• 78 Coolant Temperature Sensor
• 81 Theft Warning System (DWA)
• 82 MSR Engine Torque Regulation or AirCon Compressor (1.7.2)
• 83 ASC (EML)
• 85 AirCon Compressor Relay
• 100 Amplifier 1 in DME Control Unit
• 101 Amplifier 2 in DME Control Unit
• 150 Knock Sensor 1
• 151 Knock Sensor 2
• 152 Knock Control
• 153 Knock Control Voltage
• 200 DME Control Unit
• 201 Lambda Regulation
• 202 Control unit
• 203 Ignition system or Lambda Sensor
• 204 Idle Speed (EML)
• 205 Ignition Timing Intervention
• 206 Knock Control Test Pulse/Control Modules
• 207 Knock Control Regulated Voltage
• 210 CAN Interface
• 220 EWS 2 Immobilisation
• 252 EVAP Canister Valve
• 255 Control Unit -Internal error
• 333 Control Unit -Internal error
« แก้ไขครั้งสุดท้าย: พฤษภาคม 02, 2013, 16:20:41 โดย chaky »
Re: รายละเอียด รหัสโค๊ตต่างๆ ครับผม
« ตอบกลับ #1 เมื่อ: พฤษภาคม 02, 2013, 16:14:58 »
MS40
• 1 Ignition Fault Cylinder 1
• 2 Ignition Fault Cylinder 3
• 3 Ignition Fault Cylinder 5
• 5 Injector Fault Cylinder 6
• 6 Injector Fault Cylinder 4
• 8 Park/Neutral Switch
• 9 AirCon Compressor
• 10 AirCon Pressure Switch
• 12 Vehicle Speed Signal
• 14 EGS/DME Connection Error
• 15 EWS
• 22 Injector Fault Cylinder 3
• 23 Injector Fault Cylinder 1
• 24 AirCon Compressor
• 25 Vanos
• 27 Idle Speed Controller
• 29 Ignition Fault Cylinder 2
• 30 Ignition Fault Cylinder 4
• 31 Ignition Fault Cylinder 6
• 33 Injector Fault Cylinder 5
• 49 Power Supply Control Unit
• 50 Injector Fault Cylinder 2
• 51 Tank Ventilation
• 52 Fuel Pump
• 53 Lambda Sensor Heater
• 62 Ignition Signal Resistor
• 63 Knock Sensor Fault Bank 2
• 64 Knock Sensor Fault Bank 1
• 68 Air Flow Sensor (HFM)
• 75 Lambda Sensor Voltage
• 77 TPS
• 79 Cam Position Sensor
• 81 Coolant Temperature Sensor
• 84 Camshaft Sensor
• 85 Intake Air Temperature Sensor
• 97 Tank Ventilation Valve
• 98 Idle Speed Controller
• 99 Lambda Regulation
• 100 Control Unit Fault
• 200 Lambda Sensor Control
• 201 Idle Speed Controller
• 203 TPS
• 204 Ignition Signal Resistor
• 206 Vanos Mechanical Fault
• 207 Vehicle Speed Signal VSS
• 209 EWS Intervention
MS41, MS42 and MS43
• 1 Ignition coil Cyl 2
• 2 Ignition coil Cyl 4
• 3 Ignition coil Cyl 6
• 5 Fuel injector Cyl 2
• 6 Fuel injector Cyl 1
• 8 Air Flow Meter (HFM)
• 10 Coolant Temperature Sensor
• 11 Tank Pressure Sensor (EVAP System) or Radiator Outlet Temp (MS43)
• 12 TPS or Plausibility - Maximum Coolant Temp (MS43)
• 13 Plausibility- Radiator Outlet Temp
• 14 Intake Air Temperature Sensor
• 15 Plausibility - Cut Out Time
• 16 AirCon Compressor - PWM Signal or Plausibility Intake Air Temp (MS43)
• 17 Plausibility - Engine Coolant Temp
• 18 EWS Signal or Camshaft Sensor (MS43)
• 19 Activation VANOS Inlet Valve or Exhaust Valve (MS43)
• 20 "CHECK ENGINE" Light Failure
• 21 VANOS -Electrical Fault or Activation VANOS Inlet Valve (MS43)
• 22 Fuel Injector Cyl 3
• 23 Fuel Injector Cyl 6
• 24 Fuel Injector Cyl 4
• 25 Lambda Sensor Heater -Bank 1
• 27 Idle Control Valve - Malfunction
• 29 Ignition Coil Cyl 1
• 30 Ignition Coil Cyl 3
• 31 Ignition Coil Cyl 5
• 33 Fuel Injector Cyl 5
• 35 Aux. Air Injection System Relay
• 36 DME Main Relay
• 37 DME Main Relay : Delay
• 38 Clutch Switch -Plausibility
• 39 Brake Light Switch or Brake Light Test Switch
• 40 Brake Light Switch or Pedal Value Signal
• 42 Multi Function Steering Wheel- Plausibility
• 43 Multi Function Steering Wheel: Button
• 45 Multi Function Steering Wheel: Port
• 47 Temp Sensor -Downstream of Pre-Cat or Torque Limitation Level 1 (MS43)
• 48 DME Control Unit -Self Test 1
• 49 DME Control Unit or Torque Monitoring Level 2 (MS43)
• 50 EVAP Control Valve or Response Monitoring Level 2 (MS43)
• 51 Shut-off Valve -Charcoal Filter or Request Control Unit Reset (MS43)
• 52 Solenoid Valve -Exhaust Flap
• 53 Idle Speed Actuator
• 55 Lambda Sensor Heater -Bank 2
• 56 Ignition Current Feedback Resistor - Open Circuit
• 57 Knock sensor -Bank 1
• 58 DME Control Unit -Self Test 2
• 59 Knock Sensor -Bank 2
• 61 Lambda Sensor Heater -Bank 2 Post Cat
• 62 Aux. Air Injection System -Switching Valve
• 63 DME Control Unit or Ambient Temp Signal via CAN (MS43)
• 64 Plausibility - Ambient Temperature
• 65 Camshaft Position Sensor (Inlet MS43)
• 66 DME Control Unit
• 67 DME Control Unit
• 68 Tank Venting Valve
• 69 Fuel Pump Relay
• 70 DME Control Unit
• 71 DME Control Unit
• 72 DME Control Unit
• 74 AirCon Compressor Relay
• 75 Lambda Sensor Voltage -Bank 1
• 76 Lambda Sensor Voltage -Bank 2
• 77 Lambda Sensor Voltage -Bank 1 Post Cat
• 78 Lambda Sensor Voltage -Bank 2 Post Cat
• 79 Lambda Sensor Heater -Bank 1 Post Cat
• 80 ABS/ASC interface
• 81 MSR Signal -Active too Long
• 82 ABS/ASC Interface -Advance Adjustment
• 83 Crankshaft Sensor
• 90 Exhaust Temperature Pre Cat Conv - Bank 1
• 91 Exhaust Temperature Pre Cat Conv - Bank 2
• 92 Exhaust Temperature Post Cat Conv -Bank 1
• 93 Exhaust Temperature Post Cat Conv -Bank 2
• 94 Auxiliary Air -Air Mass Flow Sensor
• 95 Auxiliary Air Valve or Auxiliary Air Hose Blocked
• 96 Auxiliary Air Pump - Function
• 97 Auxiliary Air -Flow Rate too Low
• 98 Auxiliary Air -Flow Rate too High
• 99 Auxiliary Air Valve Jammed Open
• 100 DME Control Unit -Self-Test Failed
• 103 VANOS Error -Inlet Camshaft
• 104 VANOS Error -Exhaust Camshaft
• 105 VANOS Error -Position Inlet Camshaft
• 106 VANOS Error -Position Exhaust Camshaft
• 109 Throttle Valve Plausibility
• 110 Pedal Sensor Value Potentiometer 1
• 111 Pedal Sensor Value Potentiometer 2
• 112 TPS Potentiometer 1
• 113 TPS Potentiometer 2
• 114 Throttle Valve Final Stage
• 115 Reference Voltage -Voltage Regulator 1 or Throttle Pedal Adaptation (MS43)
• 116 Reference Voltage -Voltage Regulator 2
• 117 Plausibility -Pedal Position Sensor 1/2
• 118 Plausibility -TPS 1/2 or TPS1/Airflow Plausibility (MS43)
• 119 Throttle Valve Sensor -Mechanical Error or TPS2/Airflow Plausibility (MS43)
• 120 Plausibility Pedal Sensor or TPS
• 122 Engine Oil Temperature
• 123 Map Cooling Thermostat Control
• 124 Activation DISA Solenoid
• 125 Activation Electric Fan
• 126 Activation Tank Leak Pump Solenoid
• 127 Activation Pump Solenoid
• 128 DME/EWS Communication
• 129 CAN Signal SMG 1
• 130 CAN Signal ASC -Timeout
• 131 CAN Signal Instrument Cluster -Timeout
• 132 CAN Signal Instrument Cluster -Timeout
• 133 CAN Signal ASC -Timeout
• 134 SMG Intervention -Plausibility
• 135 Throttle Valve Re-Adaptation Required
• 136 Throttle Valve -Spring Test and Limp-home Position Failed
• 137 CAN Signal -Steering Angle Sensor
• 139 CAN Signal -Tank Level Sensor
• 140 Tank Leak Pump Solenoid - Reed Switch Open or Output Stage (MS43)
• 141 Tank Leak Pump Solenoid - Reed Switch Stuck Closed or Tank Level Sensor (MS43)
• 142 Tank Leak Pump Solenoid - Reed Switch Stuck Open or DMTL Module (MS43)
• 143 Tank Ventilation or Tank Leakage (MS43)
• 144 Fuel System - Large Leak Recognised
• 145 Fuel System - Small Leak Recognised
• 146 EVAP System Leak Detected (Small Leak) or Pedal Sensor Supply Voltage Pot 1 (MS43)
• 147 Pedal Position Sensor Potentiometer Supply Channel 1 (Pot 2 MS43)
• 149 Air Flow Sensor or Pedal Value Sensor Mismatch
• 150 Lambda Post Cat Bank 1 Max Limit
• 151 Lambda Post Cat Bank 2 Max Limit
• 152 Lambda Post Cat Bank 1 Min Limit
• 153 Lambda Pre Cat Bank 2 Max Limit
• 154 Lambda Pre Cat Bank 2 Min Limit
• 155 Lambda Pre Cat Bank 2 No Signal
• 156 Lambda Pre Cat Bank 1 No Signal
• 157 Lambda Post Cat Bank 1 Min Limit
• 159 Lambda Post Cat Bank 2 Max Limit
• 160 Lambda Post Cat Bank 2 (MS41) or Throttle Valve Stuck
• 161 Throttle Valve - Stuck
• 162 Throttle Valve -Control Deviation
• 168 Pedal Position Sensor Pot Supply 1 or MAP Cooling Thermostat Jammed (MS43)
• 169 Throttle Valve Output Stage Cut off after Fault
• 170 DME Control Unit -Self Test Failed
• 171 Plausibility - Throttle Valve
• 172 Pedal Sensor Potentiometer 1/2 Short Circuit
• 173 TPS Potentiometer 1/2 Short Circuit
• 174 Throttle Valve Potentiometer 1/2 Adaptation
• 175 Pedal Sensor 1 Adaptation
• 176 Pedal Sensor 2 Adaptation
• 186 Voltage Post Cat Bank 1
• 187 Voltage Post Cat Bank 2
• 188 Voltage Pre Cat Bank 1
• 189 Voltage Pre Cat Bank 2
• 190 EVAP -Reed Switch Open or Voltage Post Cat Bank 1 (MS43)
• 191 EVAP -Reed Switch Closed or Voltage Post Cat Bank 2 (MS43)
• 192 EVAP -Reed Switch Open
• 193 EVAP -Check Hoses
• 194 EVAP -Large Leak Detected
• 195 EVAP -Small Leak Detected
• 196 EVAP -Electrical Valve from LDP Pump or Barometric Pressure Sensor (MS43)
• 197 EVAP -Barometric Pressure Sensor
• 198 Cat Efficiency during Start -Bank 1
• 199 Cat Efficiency during Start -Bank 2
• 200 Lambda Regulation Bank 1 Pre Cat
• 201 Lambda Regulation Bank 2 Pre Cat
• 202 Lambda Regulation Bank 1 Post Cat
• 203 Lambda Regulation Bank 2 Post cat
• 204 Idle Control System -Idle speed not plausible
• 208 EWS -RPM Signal Error
• 209 EWS -Message Error
• 210 Ignition Feedback Resistor (ZSR)
• 211 Idle Speed Actuator -Mechanical
• 212 VANOS Bank 1 -Mechanical
• 214 Vehicle Speed Signal (VSS)
• 215 Lambda Sensor Bank 1 or ASC/MSR/EML -Interface not plausible
• 216 Lambda Sensor Bank 2 or EGS Position Signal
• 217 CAN bus error -EGS Signal not present
• 218 CAN module -Warning
• 219 CAN module -CAN Offline
• 220 Lambda Voltage Range Bank 1 Sensor 1
• 221 Lambda Voltage Range Bank 2 Sensor 1
• 222 Low Coolant Temperature or Lambda Sensor Control (MS43)
• 223 Lambda Sensor Switching Bank 1 Sensor 2
• 224 Lambda Sensor Switching Bank 2 Sensor 2
• 225 Cat Efficiency Bank 1
• 226 Cat Efficiency Bank 2
• 227 Mixture Deviation Bank 1
• 228 Mixture Deviation Bank 2
• 229 Lambda Sensor Switching Bank 1
• 230 Lambda Sensor Switching Bank 2
• 231 Lambda Sensor Switching Bank 1 Pre Cat
• 232 Lambda Sensor Switching Bank 2 Pre Cat
• 233 Catalytic Converter Overall Efficiency Bank 1
• 234 Catalytic Converter Overall Efficiency Bank 2
• 235 Lambda Heater Bank 1 Post Cat or Pre Cat Signal (MS43)
• 236 Lambda Heater Bank 2 Post Cat or Pre Cat Signal (MS43)
• 238 Misfire Cyl 1
• 239 Misfire Cyl 2
• 240 Misfire Cyl 3
• 241 Misfire Cyl 4
• 242 Misfire Cyl 5
• 243 Misfire Cyl 6
• 244 Crankshaft Interval Timing
• 245 Aux Air Injection System Bank 1
• 246 Aux Air Injection System Bank 2
• 247 Aux Air Injection System -Incorrect Flow Detected
• 248 Pre Cat Converter Efficiency -Bank 1
• 249 Pre Cat Converter Efficiency -Bank 2
• 250 Tank Venting Valve -Function
• 251 Tank Ventilation Diagnosis Error
• 252 Tank Ventilation System Vacuum
• 253 Activated Charcoal Filter Shut-off Valve Stuck Shut
• 254 Tank Ventilation System -Large Air Leak
• 255 Tank Ventilation System -Valve Stuck Open
« ตอบกลับ #2 เมื่อ: พฤษภาคม 02, 2013, 16:15:29 »
DME MSS50
• 1 Fuel Pump Relay
• 2 Idle Speed Actuator- Closing Coil
• 3 Fuel Injector Cyl 1
• 4 Fuel Injector Cyl 3
• 5 Fuel Injector Cyl 2
• 7 Intake Cam Position Sensor
• 8 Fault Lamp (MIL)
• 9 Ignition Current- Bank 2
• 10 Exhaust Cam Position Sensor
• 12 Lambda Sensor 1
• 13 Lambda Sensor 2
• 15 Ignition Current- Bank 1
• 19 Aux. Air Pump Relay
• 21 VANOS Retard Valve- Exhaust
• 22 VANOS Advance Valve- Exhaust
• 23 Ignition Coil- Cyl 2
• 24 Ignition Coil- Cyl 3
• 25 Ignition Coil- Cyl 1
• 29 Idle Speed Actuator- Opening Coil
• 31 Fuel Injector Cyl 5
• 32 Fuel Injector Cyl 6
• 33 Fuel Injector Cyl 4
• 36 Tank Vent Valve
• 37 Lambda Sensor Heater Relay
• 41 Mass Air Flow Sensor
• 42 Road Speed Signal VSS
• 44 Oil Level Sensor
• 46 Fuel Consumption Signal ti
• 47 Engine Speed Signal TD
• 48 AirCon Compressor Relay
• 50 Ignition Coil- Cyl 4
• 51 Ignition Coil- Cyl 6
• 52 Ignition Coil- Cyl 5
• 53 Electric Fan Relay
• 54 Vehicle System Voltage
• 67 VANOS Advance Valve- Intake
• 68 Knock Sensor 3
• 69 Knock Sensor 2
• 70 Knock Sensor 1
• 72 VANOS Retard Valve- Intake
• 73 Throttle Position Sensor TPS
• 78 Engine Coolant Temperature Sensor
• 80 Gear Recognition Switch
• 82 Starter Motor Solenoid
• 86 CAN: Signal Missing
• 66 EWS Signal Faulty
• 130 EWS Signal
• 136 Idle Speed Control Valve
• 137 CAN Protocol Fault
• 138 CAN Timeout Message 1
• 139 CAN Timeout Message 2
• 140 CAN Timeout Message 3
• 144 Lambda Sensor Control Limit- Bank 1
• 145 Lambda Sensor Control Limit- Bank 2
• 150 MSS50 Control Module Fault- Memory Test RAM Master
• 151 MSS50 Control Module Fault- Driver Fault
• 152 MSS50 Control Module Fault- Internal Communication Fault Master
• 155 MSS50 Control Module Fault- Fault Memory Master
• 156 MSS50 Control Module Fault- Fault Memory Slave
• 157 MSS50 Control Module Fault- Memory Test RAM Slave
• 158 MSS50 Control Module Fault- Internal Communication Fault Slave)
• 159 Internal SG Fault- Knock Conditioning 1
• 160 Internal SG Fault- Knock Conditioning 2
• 161 Internal SG Fault- Knock Conditioning 3
• 162 Camshaft Synchronisation
• 163 MSS50 Control Module Fault- Internal
DME MSS52 and MSS54
• 1 Fuel Pump Relay
• 7 Intake Cam Position Sensor Bank 1
• 8 Intake Cam Position Sensor Bank 2
• 9 Knock Sensor- Cyl 1-2
• 10 Exhaust Cam Position Sensor Bank 1
• 11 Exhaust Cam Position Sensor Bank 2
• 12 Lambda Sensor Signal- Pre Cat Bank 2
• 13 Lambda Sensor Signal- Pre Cat Bank 1
• 14 DMTL Heating
• 15 Camshaft Sensor Bank 1 Synchronisation
• 16 Crankshaft Sensor
• 19 Aux Air Pump Relay
• 20 Starter Relay
• 21 VANOS Retard Valve- Exhaust Bank 1
• 22 VANOS Advance Valve- Exhaust Bank 1
• 26 Ignition Coil- Cyl 8
• 27 DMTL Changeover Valve
• 29 Idle Speed Control Valve NC Coil
• 30 Internal DME Fault
• 34 Fuel Injector Cyl 7
• 35 Fuel Injector Cyl 8
• 37 Lambda Sensor Heater Pre Cat Bank 1
• 38 Lambda Sensor Heater Pre Cat Bank 2
• 39 Lambda Sensor Heater Post Cat Bank 1
• 40 Lambda Sensor Heater Post Cat Bank 2
• 41 Mass Air Flow Sensor Right
• 43 Temperature Sensor Signal- Radiator Outlet
• 44 Oil Level Sensor Signal
• 45 Electronic Throttle Motor MDK
• 48 AirCon Control Module
• 49 Internal Index 95
• 53 Electric Fan
• 54 System Voltage Main Relay
• 55 Ignition Coil- Cyl 7
• 57 Mass Air Flow Sensor Left
• 58 Sensor Voltage Supply
• 59 Sensor Voltage Supply
• 60 Throttle Pedal Position Sensor 1
• 61 Throttle Pedal Position Sensor 2
• 63 Aux Air Valve
• 65 Throttle and Electric Throttle Actuator Potentiometer
• 66 DME-EWS Communication
• 67 VANOS Advance Valve- Inlet Bank 1
• 69 Knock Sensor Cyl 3-4
• 70 Knock Sensor Cyl 7-8
• 71 Knock Sensor Cyl 5-6
• 72 VANOS Retard Valve- Inlet Bank 1
• 73 Mass Air Flow Sensor Implausible
• 74 VANOS Advance Valve- Inlet Bank 2
• 75 VANOS Retard Valve- Inlet Bank 2
• 76 Ambient Air Pressure Sensor (DME Internal)
• 79 Exhaust Gas Temperature Sensor
• 80 Switch Chain Frictional Connection
• 81 Multifunction Steering Wheel(E39)/Steering Column Lever(Z8)
• 83 VANOS Advance Valve- Exhaust Bank 2
• 84 VANOS Advance Valve- Exhaust Bank 2
• 85 Throttle Position Sensor
• 86 CAN Bus Signal
• 87 Lambda Sensor Post Cat Bank 1
• 88 Lambda Sensor Post Cat Bank 2
• 89 Internal DME Fault
• 92 Lambda Sensor Post Cat Bank 1 Voltage Monitoring
• 93 Lambda Sensor Post Cat Bank 2 Voltage Monitoring
• 99 Internal DME Fault
• 100 Tyre Pressure Front Left
• 101 Tyre Pressure Front Right
• 102 Tyre Pressure Rear Right
• 103 Tyre Pressure Rear Left
• 105 Engine Coolant Temperature Implausible
• 106 Brake Light Switch
• 107 Electronic Throttle Self Test
• 108 Oil Circuit Changeover Valve Left
• 109 Oil Circuit Changeover Valve Right
• 110 Function Light Switch Vehicle Dynamics
• 111 Throttle Pedal Position Sensor Comparison
• 112 Throttle Pedal Position Sensor Comparison
• 113 Inlet VANOS Bank 2 Function
• 114 Exhaust VANOS Bank 2 Function
• 115 Control Module Temperature or Tyre Pressure Control Button
• 116 Servotronic Valve
• 117 Servotronic- Road speed Signal
• 118 Electronic Throttle Potentiometer Bank 1
• 119 Electronic Throttle Potentiometer Bank 2
• 120 Electronic Throttle Potentiometer Comparison
• 121 Electronic Throttle Both Potentiometers Faulty
• 122 DME Internal Processor Check
• 125 Oil Level Sensor Lamp
• 126 Electric Fuel Pump Crash Deactivation
• 127 DMTL Module
• 128 Deviation Idle Speed
• 129 Cat Protection Function- Empty Tank or Low Fuel
• 130 EWS 3.3 Anti Tampering Protection
• 131 DSC Intervention Implausible
• 132 CAN Timeout DSC
• 133 CAN Timeout Steering Angle Sensor
• 134 CAN Timeout Instrument Cluster
• 135 Road Speed Signal
• 136 Idle Speed Control Function
• 139 Interruption Cruise Control Operation
• 140 Knock Control Deactivated/Knock Protection
• 141 Tank Fill Level Implausible
• 143 E-box Fan
• 144 Lambda Sensor Control Bank 1
• 145 Lambda Sensor Control Bank 2
• 149 Fuel Level
• 150 DME Memory Fault
• 151 Internal DME Fault
• 155 Saving Adaptation Values not Possible
• 156 Saving Adaptation Values not Possible
• 157 DME Memory Fault
• 158 Reset DME Over Speed
• 159 Internal DME Fault Knock Control
• 160 Internal DME Fault Knock Control
• 161 Internal DME Fault Knock Control
• 162 Camshaft Sensor Bank 2 Synchronisation
• 163 Reset DME Over Speed
• 170 Aux Air Quantity too Low
• 171 Aux Air Valve Jammed
• 172 VANOS Admission Pressure Pump
• 173 Continuous Signal Starter Switch
• 174 Fuel System Diagnosis Bank 1
• 175 Fuel System Diagnosis Bank 2
• 176 Abort Tank Leak Diagnosis due to Moisture
• 178 Catalytic Converter Efficiency Bank 1
• 179 Catalytic Converter Efficiency Bank 2
• 180 Tank Leak Detected
• 181 Fuel Filler Cap Open
• 182 Internal DME Fault
• 183 Internal DME Fault
• 184 Inlet VANOS Bank 1 Function
• 185 Exhaust VANOS Bank 1 Function
• 194 Electronic Throttle Limp Mode from Cruise Control
• 195 Deviation Setpoint Torque from Actual Torque
• 196 Misfire Cyl 1 with Cyl Cutout
• 197 Misfire Cyl 2 with Cyl Cutout
• 198 Misfire Cyl 3 with Cyl Cutout
• 199 Misfire Cyl 4 with Cyl Cutout
• 200 Misfire Cyl 5 with Cyl Cutout
• 201 Misfire Cyl 6 with Cyl Cutout
• 202 Misfire Cyl 7 with Cyl Cutout
• 203 Misfire Cyl 8 with Cyl Cutout
• 204 Misfire Multiple Cylinders with Cyl Cutout
• 205 Misfire Cyl 1 without Cyl Cutout
• 206 Misfire Cyl 2 without Cyl Cutout
• 207 Misfire Cyl 3 without Cyl Cutout
• 208 Misfire Cyl 4 without Cyl Cutout
• 209 Misfire Cyl 5 without Cyl Cutout
• 210 Misfire Cyl 6 without Cyl Cutout
• 211 Misfire Cyl 7 without Cyl Cutout
• 212 Misfire Cyl 8 without Cyl Cutout
• 213 Misfire Multiple Cylinders without Cyl Cutout
• 214 Lambda Sensor Pre Cat Bank 1 Period Duration
• 215 Lambda Sensor Pre Cat Bank 2 Period Duration
• 216 Lambda Sensor Pre Cat Bank 1 Flip Time
• 217 Lambda Sensor Pre Cat Bank 2 Flip Time
• 218 Lambda Sensor Pre Cat Bank 1 Signal Excursion
• 219 Lambda Sensor Pre Cat Bank 2 Signal Excursion
• 220 DME Internal Processor Check
• 228 Electronic Throttle Limit Violation
• 230 Electronic Throttle Setpoint/Actual Value Deviation
• 231 DME Internal Processor Check
• 232 Tank Vent Valve Function Check
• 247 VANOS Pressure Accumulator Valve
« ตอบกลับ #3 เมื่อ: พฤษภาคม 02, 2013, 16:16:07 »
DME M5.2 and M5.2.1
• 1 Activation -Solenoid Valve, Leakage Diagnosis Pump
• 2 Activation -Solenoid Valve, Fuel System Changeover
• 3 Leakage Diagnosis Pump
• 4 Lambda Sensor Heater Post Cat Bank 2
• 5 Lambda Sensor Heater Pre Cat Bank 2
• 6 CAN Instrument Cluster
• 7 Engine Coolant Temperature -Radiator
• 8 Misfire from Low Fuel
• 10 Lambda Sensor Pre Cat Bank 1 Sensor 1
• 12 Lambda Sensor Post Cat Bank 1 Sensor 2
• 13 Lambda Sensor Heater Pre Cat -No Signal Bank 1 Sensor 1
• 14 Lambda Sensor Heater Post Cat
• 15 Lambda Sensor Switching TP Pre Cat Bank 1 Sensor 1
• 16 Lambda Sensor Switching Pre Cat Bank 1
• 17 Lambda Sensor Switching Post Cat Bank 1 Sensor 2
• 18 Lambda Sensor Pre Cat Bank 2
• 19 CAN Communication with Heated Catalyst (EKAT)
• 20 Lambda Sensor Post Cat Bank 2
• 21 Lambda Sensor Switching TP Pre Cat Bank 2
• 22 Lambda Sensor Switching Duty Cycle Pre Cat Bank 2
• 23 Lambda Sensor Switching Post Cat Bank 2
• 24 AirCon Compressor Function
• 25 Multiplicative Mixture Adaptation Part Load Bank 2,
• 26 Multiplicative Mixture Adaptation Part Load Bank 1
• 27 Additive Mixture Adaptation Idle Bank 1
• 28 Additive Mixture Adaptation Idle Bank 1
• 29 Switching Solenoid for Aux Air Injection Control Circuit Bank 1
• 30 Additive Mixture Adaptation Idle Bank 1
• 31 Additive Mixture Adaptation Idle Bank 1
• 32 Idle Speed Control
• 33 Camshaft Inlet Bank 1
• 34 Camshaft Inlet Bank 2
• 35 Additive Mixture Adaptation Idle Bank 2
• 36 Additive Mixture Adaptation Idle Bank 2
• 39 EWS Immobiliser
• 40 Cat Efficiency Bank 1
• 42 EKAT -Heater Disconnected Cat 1
• 43 EKAT -Operating Condition Switch Cat 1
• 44 EKAT -Power Cat 1
• 45 Cat Efficiency Bank 2
• 46 EKAT -Heater Disconnected Cat 2
• 47 EKAT -Operating Condition Switch Cat 2
• 48 EKAT -Power Cat 2
• 50 Misfire Cyl 1
• 51 Misfire Cyl 2
• 52 Misfire Cyl 3
• 53 Misfire Cyl 4
• 54 Misfire Cyl 5
• 55 Misfire Cyl 6
• 56 Misfire Cyl 7
• 57 Misfire Cyl 8
• 58 Misfire Cyl 9
• 59 Misfire Cyl 10
• 60 Misfire Cyl 11
• 61 Misfire Cyl 12
• 62 Misfiring in Various Cyls
• 63 Misfiring with Cylinder Cutout Cyl 1
• 64 Misfiring with Cylinder Cutout Cyl 2
• 65 Misfiring with Cylinder Cutout Cyl 3
• 66 Misfiring with Cylinder Cutout Cyl 4
• 67 Misfiring with Cylinder Cutout Cyl 5
• 68 Misfiring with Cylinder Cutout Cyl 6
• 69 Misfiring with Cylinder Cutout Cyl 7
• 70 Misfiring with Cylinder Cutout Cyl 8
• 71 Misfiring with Cylinder Cutout Cyl 9
• 72 Misfiring with Cylinder Cutout Cyl 10
• 73 Misfiring with Cylinder Cutout Cyl 11
• 74 Misfiring with Cylinder Cutout Cyl 12
• 75 Misfiring in Various Cyls
• 77 Switching Solenoid for Aux Air Injection Control Circuit Bank 2
• 78 Crankshaft Sensor
• 79 Activation Aux Air Pump Bank 2
• 80 Aux Air Pump Function
• 81 EKAT Battery Temperature Sensor 1
• 82 EKAT Battery Temperature Sensor 2
• 83 EKAT Comparison Battery voltages of Power Switches Plausibility
• 84 Activation Aux Air Pump Bank 2
• 85 Activation Aux Air Pump Bank 1
• 91 Activation Tank Venting Valve Bank 2
• 93 Tank Venting System Function
• 94 Tank Venting System Large Leak
• 97 Tank Venting System Small Leak
• 98 Activation Tank Venting Valve
• 99 Tank Venting System -Pressure Sensor/Switch Range/Performance
• 101 DME Internal RAM
• 102 DME Internal RAM
• 103 DME EPROM
• 104 Fault Memory Error
• 105 Internal Control Module -RAM/ROM Error
• 107 DME Relay Voltage Supply
• 108 Voltage Supply B+
• 108 Battery Voltage
• 111 Crankshaft Position Signal
• 112 Camshaft Position Signal
• 113 Camshaft Position Signal Bank 1
• 114 Camshaft Position Signal Bank 2
• 115 Air Flow Meter HFM Signal
• 117 TPS Sensor/Switch 'A' Circuit
• 118 TPS Signal 1
• 119 TPS Signal 2
• 120 Vehicle Speed Signal VSS
• 121 Air Flow Meter HFM Load Measurement
• 123 Coolant Temperature Signal
• 124 Intake Air Temperature Signal
• 125 Output Temperature Signal
• 130 Lambda Sensor Pre Cat
• 131 Throttle Valve Stuck
• 132 Activation Throttle Valve
• 133 Activation Throttle Valve
• 134 Tank Level Switch
• 135 Specified Engine Torque -EGS Intervention
• 138 Compressor Intervention
• 139 Activation Map Cooling
• 140 Engine Torque -Bank Comparison
• 141 Dynamic Stability Control DSC Intervention
• 143 Engine Torque Control MSR Intervention
• 144 Automatic Stability Control ASC Intervention
• 147 Map Cooling Function
• 148 EWS Interface
• 149 Inlet Camshaft Setting, Bank 2
• 150 Fuel Injector Cyl 1
• 151 Fuel Injector Cyl 2
• 152 Fuel Injector Cyl 3
• 153 Fuel Injector Cyl 4
• 154 Fuel Injector Cyl 5
• 155 Fuel Injector Cyl 6
• 156 Fuel Injector Cyl 7
• 157 Fuel Injector Cyl 8
• 158 Fuel Injector Cyl 9
• 159 Fuel Injector Cyl 10
• 160 Fuel Injector Cyl 11
• 161 Fuel Injector Cyl 12
• 163 Fuel Pump Relay EKP
• 165 "CHECK ENGINE" Warning Lamp
• 167 Fuel Pump Relay EKP
• 168 Idle Speed Control Valve -Opening
• 169 Idle Speed Control Valve -Closing
• 170 AirCon Compressor Control
• 174 Camshaft Control Bank 1
• 175 DISA Control Circuit Electrical
• 178 Camshaft Control Bank 2
• 179 AirCon Compressor Control Bank 2
• 183 EVAP Emission System Leak Detected (Small)
• 184 Leakage Diagnostic Pump Clamped Hose
• 188 Emissions Warning Lamp, Bank 2(US)
• 189 Inlet Camshaft Bank 1
• 203 Ignition Circuit Monitoring
• 204 EWS Rolling Code Storage
• 208 Aux Air Injection System
• 210 Knock Sensor 1
• 211 Knock Sensor 2
• 212 Knock Sensor 3
• 213 Knock Sensor 4
• 214 CAN Interface -Version No.
• 215 CAN Interface DME Timeout
• 216 CAN Interface DSC Timeout
• 217 CAN Interface EML Timeout
• 220 Knock Control
• 222 Knock Control Bank 1
• 225 EKAT Power Switch Temperature Sensor Plausibility
• 226 Heated Catalyst Comparison Battery Voltage of Power Switches Plausibility
• 228 Automatic Start -Output Stage 2
• 233 Automatic Start -Output Stage
• 234 Automatic Start -Input
• 236 CAN Interface EGS Timeout
• 237 Automatic Start Module
• 250 Aux Air Injection System Bank 1
• 253 Coolant Fan Final Stage
• 500 EKAT Module
BMS43 and BMS46
• 1 Fuel Pump Relay
• 2 Idle Speed Controller
• 3 Injector Cylinder 2
• 4 Injector Cylinder 4
• 12 TPS
• 14 Air Flow Meter HFM
• 15 Knock Sensor 1
• 16 Camshaft Sensor
• 18 Unknown Failure or Stall
• 24 Ignition Cylinder 3
• 25 Ignition Cylinder 1
• 31 Injector Cylinder 3
• 32 Injector Cylinder 1
• 36 Tank Ventilation
• 41 Air Flow Meter HFM
• 42 Knock Sensor 1
• 44 Camshaft sensor
• 46 Electric Fan Relay
• 51 Ignition Cylinder 4
• 52 Ignition Cylinder 2
• 54 DME Power Supply
• 59 DME Power Supply
• 67 Crankshaft Sensor
• 68 Crankshaft Sensor
• 70 Lambda Sensor
• 71 Lambda Sensor
• 74 RPM Signal TD
• 76 Idle CO Potentiometer
• 77 Inlet Air Temperature Sensor
• 81 DWA / EWS
• 83 AirCon Signal
• 86 AirCon Switch
• 87 DLC Connector
• 100 Ignition Cylinder 1
• 101 Ignition Cylinder 2
• 102 Ignition Cylinder 3
• 103 Ignition Cylinder 4
• 104 Injector Cylinder 1
• 105 Injector Cylinder 2
• 106 Injector Cylinder 3
• 107 Injector Cylinder 4
• 108 Electric Ventilator
• 110 AirCon Compressor
• 111 Fuel Pump
• 112 Air Inlet Regulator Valve
• 113 EVAP Solenoid Valve
• 114 Outlet Valve
• 115 Coolant Temperature Sensor
• 117 Idle Speed Controller
• 118 Lambda Sensor Heating Pre Cat
• 119 TPS
• 120 Air Mass Meter HFM
• 121 Inlet Air Temperature Sensor
• 122 Coolant Temperature Sensor
• 123 Coolant Temperature Sensor
• 124 Battery Voltage
• 125 Lambda Sensor Pre Cat
• 126 CAN Signal ASC
• 127 CAN Signal ASC
• 128 CAN Signal EGS
• 129 CAN Signal EGS
• 130 CAN Signal Instrument Cluster
• 131 Vehicle Speed Signal VSS
• 132 Air Mass Meter HFM -Reference Voltage
• 133 TPS Reference Voltage
• 135 Camshaft Sensor
• 136 Crankshaft sensor
• 137 Knock Sensor 1
• 138 Knock Sensor 2
• 139 Lambda Sensor Post Cat
• 140 DWA /EWS
• 141 Lambda Regulation
• 142 Knock Regulation
• 143 DME Control Unit
• 144 EWS Manipulation
• 145 Misfire / Detonation Cylinder 1
• 146 Misfire / Detonation Cylinder 2
• 147 Misfire / Detonation Cylinder 3
• 148 Misfire / Detonation Cylinder 4
• 149 Aux. Air Pump Valve
• 150 Aux. Air Pump
• 151 Aux. Air Pump -Plausibility
• 152 Aux. Air Pump -Test Error
• 153 Lambda Sensor Heating Post Cat
• 155 Misfire Detected -Various Cylinders
• 156 Misfire / Detonation Cylinder 1
• 157 Misfire / Detonation Cylinder 2
• 158 Misfire / Detonation Cylinder 3
• 159 Misfire / Detonation Cylinder 4
• 160 Misfire Detected -Various Cylinders
• 165 Catalytic Converter
• 166 Lambda Sensor Pre Cat
• 169 Lambda Sensor 1 Heating Pre Cat
• 170 Lambda Sensor 2 Heating Pre Cat
• 171 Fuel Supply / Mixture Control
• 202 DME Control unit
• 203 Ignition System
• 204 Idle Speed RPM
• 206 Knock Regulation
• 216 CAN Signal ASC
• 220 EWS No Signal
• 236 CAN Signal EGS
DME 7.2
• 1 Leak Diagnosis pump
• 2 DMTL Output Stage Solenoid Valve
• 3 Lambda Sensors Pre Cat Swapped
• 10 Lambda Sensor Pre Cat Bank 1 Signal
• 12 Lambda Sensor Post Cat Bank 1 Signal
• 13 Lambda Sensor Heater Pre Cat Bank 1
• 14 Lambda Sensor Heater Post Cat Bank 1
• 15 Lambda Sensor Timing Pre Cat Bank 1 (TP)
• 16 Lambda Sensor Timing Pre Cat Bank 1 (TV)
• 17 Lambda Sensor Timing Pre Cat Bank 1
• 18 Lambda Sensor Pre Cat Bank 2 Signal
• 20 Lambda Sensor Post Cat Bank 2 Signal
• 21 Lambda Sensor Timing Pre Cat Bank 2 (TP)
• 22 Lambda Sensor Timing Pre Cat Bank 2 (TV)
• 23 Lambda Sensor Timing Post Cat Bank 2
• 24 Multiplicative Adaptation Bank 1 Control Limit Reached
• 25 Multiplicative Adaptation Bank 2 Control Limit Reached
• 26 Multiplicative Adaptation Bank 1 Control Limit Reached
• 27 Multiplicative Adaptation Bank 2 Control Limit Reached
• 28 Additive Adaptation Bank 1 Control Limit Reached
• 29 Additive Adaptation Bank 2 Control Limit Reached
• 30 Short Term Additive Adaptation Bank 1 Control Limit Reached
• 31 Short Term Additive Adaptation Bank 2 Control Limit Reached
• 33 Inlet Camshaft Control Bank 1
• 34 Inlet Camshaft Control Bank 2
• 39 EWS 3.3 Anti Tampering Protection
• 40 Catalytic Converter Efficiency Bank 1
• 45 Catalytic Converter Efficiency Bank 2
• 50 Misfire Detection Cyl 1
• 51 Misfire Detection Cyl 5
• 52 Misfire Detection Cyl 4
• 53 Misfire Detection Cyl 8
• 54 Misfire Detection Cyl 6
• 55 Misfire Detection Cyl 3
• 56 Misfire Detection Cyl 7
• 57 Misfire Detection Cyl 2
• 62 Misfire at Multiple Cylinders
• 80 Aux Air System Bank 1
• 81 Aux Air System Bank 2
• 82 Aux Air System Valve
• 84 Aux Air Pump Relay
• 85 Aux Air System Valve
• 98 Tank Vent Valve
• 101 Torque Monitoring
• 102 Multifunction Steering Wheel Signal
• 103 Control Unit Monitoring
• 104 Clutch Switch Signal
• 105 Control Unit Fault (RAM)
• 106 Brake Switch Signal
• 107 Control Unit Fault (ROM)
• 108 Reset DME / Voltage Supply
• 109 Battery Voltage
• 110 Torque Monitoring
• 111 Crankshaft Sensor Signal
• 112 Crankshaft Sensor Signal
• 113 Camshaft Position Sensor Bank 1
• 114 Camshaft Position Sensor Bank 2
• 115 Mass Air Flow Sensor Signal
• 117 Throttle Potentiometer Signal
• 118 Throttle Potentiometer 1 Signal
• 119 Throttle Potentiometer 2 Signal
• 121 CAN Signal Wheel Speed
• 122 Ambient Temperature Signal
• 123 Engine Coolant Temperature Sensor
• 124 Intake Air Temperature Sensor
• 125 Radiator Outlet Temperature Sensor
• 127 TxD Plausibility
• 130 Throttle Actuator
• 131 Throttle Actuator Jammed
• 132 Throttle Actuator Activation
• 133 Throttle Actuator Spring Check
• 134 Throttle Actuator Adaptation Lower Stop
• 135 Throttle Potentiometer Booster Adjustment
• 136 Throttle Emergency Operation Point
• 139 Thermostat Jammed
• 140 Map Cooling Thermostat Activation
• 141 Electric Fan Activation
• 142 Exhaust Flap Activation
• 148 Interface DME-EWS
• 150 Fuel Injector Activation Cyl 1
• 151 Fuel Injector Activation Cyl 5
• 152 Fuel Injector Activation Cyl 4
• 153 Fuel Injector Activation Cyl 8
• 154 Fuel Injector Activation Cyl 6
• 155 Fuel Injector Activation Cyl 3
• 156 Fuel Injector Activation Cyl 7
• 157 Fuel Injector Activation Cyl 2
• 163 Throttle Mass Air Flow Adjustment Diagnosis
• 164 Ambient Pressure Sensor
• 165 Inlet VANOS Bank 1
• 166 Inlet VANOS Bank 2
• 167 Electric Fuel Pump EKP Relay
• 168 MIL Fault Lamp
• 182 Tank Leakage Detection Minor Leak
• 183 Tank Leakage Detection
• 184 Tank Leakage Detection Blocked Line
• 185 Tank Leakage Diagnosis Pump
• 186 DMTL Pump Motor
• 187 DMTL Minimal Leak (0.5mm)
• 188 DMTL Minor Leak (1.0mm)
• 189 DMTL Module
• 201 DMTL Heating
• 204 EWS 3.3 Random Code Storage
• 210 Knock Sensor Signal 1
• 211 Knock Sensor Signal 2
• 212 Knock Sensor Signal 3
• 213 Knock Sensor Signal 4
• 214 Knock Control Zero Test
• 215 Knock Control Offset
• 216 Knock Control Test Pulse
• 219 CAN Timeout TCU
• 220 CAN Timeout (EGS/AGS)
• 221 CAN Timeout ASC/DSC
• 222 CAN Timeout Instrument Cluster
• 223 CAN Timeout ACC
• 224 MSR Intervention Plausibility
• 225 ACC Intervention Plausibility
• 226 Tank Fill Level Plausibility
• 229 Pedal Travel Sensor Comparison
• 230 Pedal Travel Sensor Signal
• 231 Pedal Travel Sensor Signal Potentiometer 1
• 232 Pedal Travel Sensor Signal Potentiometer 2
• 233 Automatic Start Activation
• 234 Ignition Lock Signal (T50)
• 236 Intake Flap Activation
• 237 Automatic Start Activation sis Pump
« ตอบกลับ #4 เมื่อ: พฤษภาคม 02, 2013, 16:16:37 »
ME 9
• 2712 DMTL Solenoid Valve Activation
• 2713 Lambda Sensors Pre Cat Swapped
• 2714 Lambda Sensor Heater Post Cat Bank 2
• 2715 Lambda Sensor Heater Pre Cat Bank 2
• 2716 Lambda Sensor Heater Post Cat Bank 1
• 2717 Lambda Sensor Heater Post Cat Bank 2
• 2718 Crankshaft Sensor Reference
• 2719 Crankshaft Sensor Period
• 271A Lambda Sensor Pre Cat Bank 1- Signal
• 271C Lambda Sensor Post Cat Bank 1- Signal
• 271D Lambda Sensor Heater Pre Cat Bank 1
• 271E Lambda Sensor Heater Post Cat Bank 1
• 271F Lambda Sensor Timing Period
• 2720 Lambda Sensor Timing Switching Time
• 2721 Lambda Sensor Timing Post Cat Bank 1
• 2722 Lambda Sensor Pre Cat Bank 2- Signal
• 2724 Lambda Sensor Post Cat Bank 2- Signal
• 2725 Lambda Sensor Timing Bank 2- Period
• 2726 Lambda Sensor Timing Bank 2- Switching Time
• 2727 Lambda Sensor Timing Post Cat Bank 2
• 272A Multiplicative Adaptation Bank 1- Control Limit Reached
• 272B Multiplicative Adaptation Bank 2- Control Limit Reached
• 272C Additive Adaptation Bank 1- Control Limit Reached
• 272D Additive Adaptation Bank 2- Control Limit Reached
• 2731 Inlet Camshaft Control
• 2734 Throttle Valve Potentiometer 1- Signal Implausible to Mass Air Flow Sensor
• 2735 Throttle Valve Potentiometer 2- Signal Implausible to Mass Air Flow Sensor
• 2737 EWS 3.3 Anti Tampering Protection
• 2738 Catalytic Converter Efficiency Bank 1
• 2739 Catalytic Converter Efficiency Bank 1
• 273A Catalytic Converter Efficiency Bank 2
• 273D Catalytic Converter Efficiency Bank 2
• 2740 Pedal Position Sensor 1- Voltage Supply
• 2741 Pedal Position Sensor 2- Voltage Supply
• 2742 Misfire Detection Cyl 1
• 2743 Misfire Detection Cyl 3 (4cyl) or 5 (6 cyl)
• 2744 Misfire Detection Cyl 4 (4cyl) or 3 (6 cyl)
• 2745 Misfire Detection Cyl 2 (4cyl) or 6 (6 cyl)
• 2746 Misfire Detection Cyl 2
• 2747 Misfire Detection Cyl 4
• 274E Misfire Detection All Cyls
• 2750 Throttle Position Controller- Jammed Briefly
• 2751 Throttle Position Controller- Jammed Permanently
• 2752 Throttle Position Controller- Jamming
• 2753 Ignition Coil Cyl 1
• 2754 Ignition Coil Cyl 3 (4cyl) or 5 (6 cyl)
• 2755 Ignition Coil Cyl 4 (4cyl) or 3 (6 cyl)
• 2756 Ignition Coil Cyl 2 (4cyl) or 6 (6 cyl)
• 2757 Ignition Coil Cyl 2
• 2758 Ignition Coil Cyl 4
• 2760 Aux Air System Bank 1
• 2761 Aux Air System Bank 2
• 2764 Aux Air Pump Relay
• 2765 Solenoid Valve- Aux Air- Activation
• 2766 Inlet Camshaft Sensor- Signal Duration
• 2767 Exhaust Camshaft Sensor- Signal Duration
• 2768 Inlet Camshaft Sensor- Phase Position
• 2769 Throttle Actuator Spring Test
• 276C Exhaust Camshaft Sensor- Phase Position
• 276D Tank Venting System
• 2770 Aux Air Mass Air Flow Sensor
• 2772 Tank Vent Valve Output Stage
• 2774 CAN Message- Engine Shutdown Time
• 2775 Engine Torque Monitoring Level 2
• 2776 Multifunction Steering Wheel Interface
• 2777 DME Self Test: Monitoring AD Converter
• 2778 Clutch Switch
• 2779 DME Self Test RAM
• 277A Brake Light Switch
• 277B DME Self Test ROM
• 277C DME Self Test RESET
• 277D Battery Voltage
• 277E Engine Torque Monitoring Level 1
• 277F Crankshift Sensor Speed
• 2780 Crankshift Sensor Reference
• 2781 Camshaft Sensor Intake
• 2782 Camshaft Sensor Exhaust
• 2783 Mass Air Flow Sensor
• 2786 Throttle Valve Potentiometer 1
• 2787 Throttle Valve Potentiometer 2
• 2788 Vehicle Speed
• 2789 Rough Running Detection
• 278A Ambient Temperature Sensor
• 278B Engine Coolant Temperature Sensor
• 278C Intake Air Temperature Sensor
• 278D Radiator Outlet Temperature Sensor
• 278E Differertial Pressure Sensor- Intake Manifold
• 278F Alternator - Under-Excitation
• 2790 Radiator Outlet Temperature
• 2791 Throttle Adaptation Required
• 2792 Throttle Actuator Position Monitoring
• 2793 Throttle Actuator Control Range
• 2794 Throttle Actuator Activation
• 2795 Throttle Actuator Spring Test
• 2796 Throttle Actuator Test Lower Stop
• 2797 Throttle Actuator Booster Adjustment
• 2798 Throttle Actuator Emergency Operating Point
• 2799 Throttle Actuator Adaptation Aborted Environmental Conditions
• 279A Throttle Actuator Relearn Abort
• 279B Map Cooling Thermostat Mechanism
• 279C Map Cooling Thermostat Output Stage
• 279D Electric Fan Output Stage
• 279E Exhaust Flap Output Stage
• 27A0 E-Box Fan Activation
• 27A1 Throttle- Starting Test
• 27A4 Interface DME-EWS
• 27A5 Throttle Adaptation
• 27A6 Fuel Injector Cyl 1
• 27A7 Fuel Injector Cyl 3 (4cyl or 5 (6cyl)
• 27A8 Fuel Injector Cyl 4 (4cyl or 3 (6cyl)
• 27A9 Fuel Injector Cyl 2 (4cyl or 6 (6cyl)
• 27AA Fuel Injector Cyl 2
• 27AB Fuel Injector Cyl 4
• 27B2 Brake Light Switch- Signal
• 27B3 Throttle - Mass Air Flow Adjustment Plausibility
• 27B4 Ambient Pressure Sensor
• 27B5 Inlet Camshaft Control Output Stage
• 27B7 Fuel Pump Relay Output Stage
• 27B8 Differential Pressure Sensor Intake Manifold Plausibility
• 27B9 Lambda Sensor Pre Cat Bank 1- Voltage Excursion
• 27BA Lambda Sensor Pre Cat Bank 2- Voltage Excursion
• 27BB Exhaust Camshaft Control
• 27BD Exhaust Camshaft Control Output Stage
• 27C1 All Camshaft Sensors Failed
• 27C2 AirCon Compressor Control Output Stage
• 27C3 Oil Level Sensor
• 27C4 Main Relay
• 27C5 Brake Light Test Switch- Signal
• 27C7 Main Relay Switching Time
• 27CA DMTL Pump Motor- Activation
• 27CC DMTL Leakage
• 27CD DMTL Module Failure
• 27CE Load Monitoring
• 27CF Firing Cyl 1
• 27D0 Firing Cyl 5
• 27D1 Firing Cyl 3
• 27D2 Firing Cyl 6
• 27D3 Firing Cyl 2
• 27D4 Firing Cyl 4
• 27D6 Idle Speed Control Valve- Activation - Position Closed
• 27D7 Idle Speed Control Valve- Activation - Position Open
• 27D9 DMTL Heater- Activation
• 27DA Alternator BSD Fault
• 27DB Accelerator and Brake Pedals- Signal
• 27DC EWS 3.3 Random Code Storage
• 27DD Engine Coolant Temp Sensor- Gradient
• 27DE Engine Coolant Temp Sensor- Signal
• 27DF Engine Coolant Temp Sensor- Signal Constant
• 27E0 Crank Position Sensor- Segment Timing
• 27E1 Pedal Travel Sensor Monitoring
• 27E2 Knock Sensor 1
• 27E3 Knock Sensor 2
• 27E6 Knock Control Zero Test
• 27E7 Knock Control Offset
• 27E8 Knock Control Test Pulse
• 27EB CAN message EGS
• 27EC CAN message EGS
• 27ED CAN message ASC/DSC
• 27EE CAN message Instrument Cluster
• 27F2 Tank Fill Level
• 27F3 CAN message Valvetronic Control Unit
• 27F7 Pedal Travel Sensor Potentiometer 1
• 27F8 Pedal Travel Sensor Potentiometer 2
• 27FB Radiator Shutter
• 2800 CAN message Instrument Cluster
• 2804 Cruise Control Request
• 2805 Cruise Control Switch Signal
• 2806 Cruise Control Data Transmission
• 2807 Throttle Position Sensor Implausible- 1 vs. 2
• 2808 Throttle Position Sensor Implausible- Ratio
• 2809 CAN message Instrument Cluster
• 280B CAN message DSC
• 280C CAN message DSC
• 280D CAN message Steering Angle Sensor
• 280E CAN message SMG
• 280F CAN message DSC
• 2811 Local CAN Communication Error
• 2812 Oil Temperature
• 2813 DME Monitoring Group A
• 2814 DME Monitoring Group B
• 2815 DME Monitoring Group C
• 2816 DME Monitoring Speed Sensor or ECU Fault
• 281A CAN No Message TxU
• 281C BSD Interface Signal
• 281D BSD Signal
• 281E DISA Intake System Output Stage
• 2823 Lambda Sensor Heater Pre Cat Bank 1
• 2824 Lambda Sensor Heater Pre Cat Bank 2
• 2825 Lambda Sensor Timing Bank 1
• 2826 Lambda Sensor Timing Bank 2
• 282F CAN Communication Fault
• 2830 DME Self Test Checksum
• 2831 DME Self Test Processor Monitoring
• 283A Oil Condition Sensor
• 283D PT-CAN Communication Error
• 283E Variable Valve Gear Output Stage Enable Line
• 283F Oil Pressure Switch Implausibility
• 2850 Variable Valve Gear Guide Sensor
• 2852 Variable Valve Gear Reference Sensor
• 2854 Variable Valve Gear Plausibility Sensor
• 2856 Variable Valve Gear Voltage Supply
• 2858 Variable Valve Gear Adaptation Function
• 285A Variable Valve Gear Servomotor Monitoring
• 285C Variable Valve Gear CAN Communication
• 285E Variable Valve Gear Control Unit Internal Fault
• 2860 Variable Valve Gear Servomotor Output Stage
• 2862 Variable Valve Gear Voltage Supply Power Output Stage
• 2865 Variable Valve Gear Torque Limitation- Limp Mode
• 2866 Variable Valve Gear Adaptation Needed
• 2867 Variable Valve Gear Overload
• 286A DME Self Test- Knock Sensor Module
• 286B DME Self Test- Multiple Output Module
• 2882 Fuel Trim Bank 1
• 2883 Fuel Trim Bank 2
• 2892 Misfiring
• 2893 Control Module Temperature
• 2894 Control Module Fault
• 2895 Crankshaft Sensor- Signal
• 2896 Inlet Camshaft Sensor- Signal
• 2897 Exhaust Camshaft Sensor- Signal
• 2898 Lambda Sensor Post Cat- Bank 1 Signal
• 2899 Lambda Sensor Post Cat- Bank 2 Signal
• 289A Lambda Sensor Heater Pre Cat- Bank 1 Function
• 289B Lambda Sensor Heater Pre Cat- Bank 2 Function
• 289C Lambda Sensor Heater Post Cat- Bank 1 Function
• 289D Lambda Sensor Heater Post Cat- Bank 2 Function
• 289E Lambda Sensor Pre Cat Bank 1
• 289F Lambda Sensor Pre Cat Bank 2
• 28A1 Cruise Control -Monitoring
• 28A2 Air Flow -Monitoring
• 28A4 Engine Speed -Monitoring
• 28A5 Pedal Position Sensor -Monitoring
• 28AA Idle Control -Monitoring
• 28AB External Torque Request -Monitoring
• 28AC Specified Torque -Monitoring
• 28AD Actual Torque -Monitoring
• 28B1 Speed Limitation -Monitoring
• 28B2 Speed Limitation -Reset
• 28B3 Throttle -Continuous Adaptation
• 28B4 Button -Driving Dynamics Control
• 28B5 Sound Flap -Signal
• 28B6 Inlet Camshaft -Mechanical
• 28B8 Exhaust Camshaft -Mechanical
• 28BA Inlet Camshaft -Stiff
• 28BC Exhaust Camshaft -Stiff
• 28BD Inlet Camshaft Sensor -Locking
• 28BE Exhaust Camshaft Sensor -Locking
• 28C1 Lambda Sensor Pre Cat Bank 1
• 28C2 Lambda Sensor Pre Cat Bank 2
• 28C3 Lambda Sensor Heater Pre Cat Bank 1 Function
• 28C4 Lambda Sensor Heater Pre Cat Bank 2 Function
• 28C5 Lambda Sensor Post Cat Bank 1 System Check
• 28C6 Lambda Sensor Post Cat Bank 2 System Check
• 28CA Ozone Conversion- Too Low
• 28CB Ozone Sensor 2
• 28CC Ozone Sensor 1
• 28CF Fuel Pump- Emergency Shutoff
• 28D0 Fuel Pump- Monitoring
• 28D6 Process Error- Coding
• 28D7 Alternator Communication
• 28D8 RAM Backup
• 28DB Variable Valve Gear Minimum Lift Adaptation Exceeded
• 28DD Air Mass System
• 28E6 Evaluation Module Lambda Sensor Bank 1 On-board Diagnosis
• 28E7 Evaluation Module Lambda Sensor Bank 2 On-board Diagnosis
• 28E8 Lambda Sensor Bank 1 Trim Control
• 28E9 Lambda Sensor Bank 2 Trim Control
• 28EA Lambda Sensor Post Cat Bank 1 Signal
• 28EB Lambda Sensor Post Cat Bank 2 Signal
• 28EC Lambda Sensor Post Cat Bank 1 Signal at Full Load
• 28ED Lambda Sensor Post Cat Bank 2 Signal at Full Load
• 28F0 Lambda Sensor Post Cat Bank 1 System Check
• 28F1 Lambda Sensor Post Cat Bank 2 System Check
• 28F2 Lambda Sensor Bank 1 Trim Control
• 28F3 Lambda Sensor Bank 2 Trim Control
• 28F4 Lambda Sensor Pre Cat Bank 1 Cold Test
• 28F5 Lambda Sensor Pre Cat Bank 2 Cold Test
• 28F6 Lambda Sensor Post Cat Bank 1 Cold Test
• 28F7 Lambda Sensor Post Cat Bank 2 Cold Test
• 28F9 Rough Running- Segment Time Measurement
• 28FA CAN Torque for Switching Phase
• 28FB Active Cruise Control (ACC)
• 28FF DME Self Test
• 2900 DME Self Test
• 2960 Lambda Sensor Pre Cat Bank 1
• 2961 Lambda Sensor Pre Cat Bank 2
• 2962 Lambda Sensor Pre Cat Bank 1 Dynamics
• 2963 Lambda Sensor Pre Cat Bank 2 Dynamics
• 2964 Lambda Sensor Pre Cat Bank 1 Ceramic Temperature
• 2965 Lambda Sensor Pre Cat Bank 2 Ceramic Temperature
• 2966 Lambda Sensor Pre Cat Bank 1 Signal
• 2967 Lambda Sensor Pre Cat Bank 2 Signal
• 296A Lambda Sensors Pre Cat Swapped
• 296B Lambda Sensors Post Cat Swapped
• 2972 Jet Pump for Brake Servo
• 2973 Lambda Sensor Pre Cat Bank 1 Lines
• 2974 Lambda Sensor Pre Cat Bank 2 Lines
• 2986 Lambda Sensor Pre Cat Bank 1 System Check
• 2987 Lambda Sensor Pre Cat Bank 2 System Check
• 2988 Lambda Sensor Pre Cat Bank 1 System Check
• 2989 Lambda Sensor Pre Cat Bank 2 System Check
• 299A CAN Fault Management EGS
• 299B Battery Sensor
• 299C Battery Sensor
• 299D Battery Sensor
• 299E Lambda Sensor Post Cat Bank 1 Signal
• 299F Lambda Sensor Post Cat Bank 1 Signal
• 29A0 Lambda Sensor Post Cat Bank 2 Signal
• 29A1 Lambda Sensor Post Cat Bank 2 Signal
• 29A2 Lambda Sensor Pre Cat Bank 2 Signal
• 29A3 Lambda Sensor Pre Cat Bank 2 Signal
• 29A4 Lambda Sensor Heater Pre Cat Bank 1 Activation
• 29A5 Lambda Sensor Heater Pre Cat Bank 2 Activation
• 29A6 Lambda Sensor Pre Cat Bank 1 Signal
• 29A7 Lambda Sensor Pre Cat Bank 1 Signal
• 29A8 Power Management Vehicle Electrical System
• 29A9 Power Management Battery
• 29AB Torque Request via CAN
• 29AE Tank Cap
• 29B5 Aux Air System
• 29B6 Cylinder Cutout
• 29CC Misfire Several Cylinders
• 29CD Misfire Cyl 1
• 29CE Misfire Cyl 2
• 29CF Misfire Cyl 3
• 29D0 Misfire Cyl 4
• 29DD Rough Running Detection
• 29E5 Mixture Adaptation 1 Air Density Upper Speed Range
• 29E6 Mixture Adaptation 2 Air Density Upper Speed Range
• 29E7 Mixture Adaptation 1 Air Leak
• 29E8 Mixture Adaptation 2 Air Leak
• 29ED Mixture Adaptation 1 Air Density Lower Speed Range
• 29EE Mixture Adaptation 2 Air Density Lower Speed Range
• 29F4 Catalytic Converter Efficiency 1
• 29FE Aux Air System
• 29FF Aux Air System
• 2A03 Aux Air Pump Relay
• 2A19 Tank Venting Valve
• 2A59 Valvetronic Eccentric Shaft Sensor 1
• 2A5B Valvetronic Eccentric Shaft Sensor 1
• 2A5D Valvetronic Eccentric Shaft Sensor 1
• 2A5F Valvetronic Eccentric Shaft Sensor 1
• 2A61 Valvetronic Adaptation 1
• 2A63 Valvetronic Servomotor 1
• 2A67 Valvetronic Internal Fault
• 2A69 Valvetronic Voltage Supply Servomotor 1
• 2A6B Valvetronic Power Limitation Servomotor
• 2A6C Valvetronic Adaptation
• 2A6D Valvetronic Electrical Overload Protection 1
• 2A6F Valvetronic Minimum Lift Exceeded
• 2A70 Valvetronic Servomotor
• 2A71 Valvetronic Relief Relay
• 2A80 Inlet VANOS Activation 1
• 2A83 Inlet VANOS 1
• 2A85 Exhaust VANOS Activation 1
• 2A88 Exhaust VANOS 1
• 2B5C Crankshaft Sensor
• 2B5D Crankshaft Sensor
• 2B62 Camshaft Sensor 1 Inlet
• 2B63 Camshaft Sensor 2 Exhaust
• 2B66 Camshaft Sensor
• 2B70 Variable Intake System
• 2B7F Idle Speed Control
• 2B80 Idle Speed Control
• 2B8A Control Module- Internal Fault Knock Control
• 2B8B Control Module- Internal Fault Knock Control
• 2B8C Control Module- Internal Fault Knock Control
• 2B98 Control Module- Internal Fault RAM
• 2B99 Control Module- Internal Fault RAM
• 2B9A Control Module- Internal Fault RAM
• 2B9B Control Module- Internal Fault ROM
• 2B9C Control Module- Internal Fault Reset
• 2BA7 Engine Torque too High
• 2C24 Lambda Sensors Pre Cat Swapped
• 2C45 Lambda Sensor Pre Cat 1
• 2C46 Lambda Sensor Pre Cat 2
• 2C6A Lambda Sensor Post Cat Swapped
• 2C6D Lambda Sensor Post Cat 1 Timing
• 2C6E Lambda Sensor Post Cat 2 Timing
• 2C6F Lambda Sensor Post Cat 1
• 2C70 Lambda Sensor Post Cat 2
• 2C71 Lambda Sensor Post Cat 1
• 2C72 Lambda Sensor Post Cat 2
• 2C9C Lambda Sensor Heater Pre Cat 1
• 2C9D Lambda Sensor Heater Pre Cat 2
• 2CA0 Lambda Sensor Heater Pre Cat 1
• 2CA1 Lambda Sensor Heater Pre Cat 2
• 2CA2 Lambda Sensor Heater Pre Cat 1
• 2CA3 Lambda Sensor Heater Pre Cat 2
• 2CA8 Lambda Sensor Heater Post Cat 1
• 2CA9 Lambda Sensor Heater Post Cat 2
• 2CEF Throttle Valve Actuator
• 2CF0 Throttle Valve Actuator
• 2CF1 Throttle Valve Actuator
• 2CF8 Throttle Valve Potentiometer
• 2CF9 Throttle Valve Potentiometer 1
• 2CFA Throttle Valve Potentiometer 2
• 2CFF Throttle Valve Actuator
• 2D00 Throttle Valve Actuator
• 2D01 Throttle Valve Actuator
• 2D02 Throttle Valve Actuator
• 2D03 Throttle Valve Actuator
• 2D04 Throttle Valve Actuator
• 2D05 Throttle Valve Actuator
• 2D08 Throttle Actuator
• 2D0F Mass Air Flow Sensor Signal
• 2D19 Accelerator Pedal Module
• 2D1A Accelerator Pedal Module
• 2D1B Accelerator Pedal Module Signal 1
• 2D1C Accelerator Pedal Module Signal 2
• 2D28 Intake Manifold Pressure Sensor Signal
• 2D29 Intake Manifold Pressure Sensor Plausibility
• 2D6E Control Module Internal Fault Torque Monitoring
• 2D6F Load Sensor Monitoring
• 2D70 Control Module Internal Fault
• 2D71 Control Module Internal Fault
• 2D72 Control Module Internal Fault
• 2D73 Fuel Pressure Sensor
• 2D74 Fuel Pressure Sensor
• 2D75 Crankshaft Sensor
• 2D76 Accelerator Pedal Module
• 2E24 Ignition Coil Cyl 1
• 2E25 Ignition Coil Cyl 2
• 2E26 Ignition Coil Cyl 3
• 2E27 Ignition Coil Cyl 4
• 2E30 Fuel Injector Cyl 1
• 2E31 Fuel Injector Cyl 2
• 2E32 Fuel Injector Cyl 3
• 2E33 Fuel Injector Cyl 4
• 2E68 Knock Sensor Signal 1
• 2E69 Knock Sensor Signal 2
• 2E95 Generator
• 2E97 Generator
• 2EE0 Engine Coolant Temperature Sensor Signal
• 2EEA Radiator Outlet Temperature Sensor Signal
• 2EF4 Map Thermostat Mechanism Jammed
• 2EF5 Map Thermostat Activation
• 2EFE Electric fan
• 2F08 Intake Air Temperature Sensor Signal
• 2F12 AirCon Compressor Relay
• 2F17 Engine Oil Temperature too High
• 2F44 EWS Intervention
• 2F45 EWS Data Line
• 2F46 EWS Calibration
• 2F4E Road Speed Signal
• 2F62 Brake Light Switch
• 2F67 Clutch Switch
• 2F76 Control Module Internal Fault Ambient Pressure Sensor
• 2F85 Control module Internal fault Internal Temperature Sensor
• 2F8A Power Supply
• 2F94 Fuel Pump Relay Activation
• 2F99 External Temperature Sensor Plausibility
• 2F9E Oil Level Sensor
• 2FA3 Coding Error
« ตอบกลับ #5 เมื่อ: พฤษภาคม 02, 2013, 16:17:04 »
DDE 1
• 1 RPM Sensor
• 2 Fuel Temperature Sensor
• 3 Coolant Temperature Sensor
• 4 Pedal Position Sensor
• 5 Boost Pressure Sensor
• 6 TPS
• 7 Boost Pressure Regulator
• 8 Air Mass Meter
• 10 Speed Regulator
• 11 DDE Error
• 12 Inlet Air Temperature Sensor
• 13 RPM Signal
• 14 Injection Phasing Sensor
• 15 Exhaust Gas Recirculation
• 16 Injection Phasing Regulator
• 17 Brake Light Test Switch
• 36 Coolant Level Sensor
« ตอบกลับ #6 เมื่อ: พฤษภาคม 02, 2013, 16:17:19 »
DDE 2 and DDE 2.1
• 1 Injection Pump Mass Positioner
• 3 Shut off Valve
• 5 Injection Start Sensor Cyl4
• 6 Glow Plug Timing Control
• 8 Exhaust Gas Recirculation
• 10 Injection Phasing Control Deviation
• 15 Voltage Supply DDE
• 20 Cruise Control Switch
• 21 Injection Pump Position Potentiometer
• 28 Clutch switch
• 29 Vehicle Speed Signal
• 31 Brake Switch
• 35 Fuel Temperature Sensor
• 36 Fuel Filter Water Trap
• 37 Pedal Position Sensor
• 41 Glow Plug Timing Control
• 45 DWA Immobiliser
• 47 RPM Sensor
• 52 Charge Air Temperature Sensor
• 53 Coolant Temperature Sensor
• 54 Boost Pressure Sensor
• 56 DDE Internal Fault
• 58 DDE Output Stage Error
• 59 Boost Pressure Deviation
« ตอบกลับ #7 เมื่อ: พฤษภาคม 02, 2013, 16:17:38 »
DDE 2.2
• 01 Delivery Controller Deviation
• 03 Shut off Valve
• 04 Glow Plug Indicator Lamp)
• 05 Needle Motion Sensor
• 06 Exhaust Gas Recirculation Deviation
• 07 Exhaust Gas Recirculation
• 08 Glow Plug Timing Control
• 09 DDE Error
• 11 DDE Error
• 15 DDE Power Supply -Main Relay
• 16 Voltage Supply B+
• 20 Cruise Control Operation
• 21 DDE Error
• 23 AirCon Signal
• 25 Pedal Position Sensor
• 26 Brake Light Switch or Brake Light Test Switch
• 28 Auto Gearbox Selector Switch
• 30 EGR Switch
• 31 Brake Light Test Switch
• 32 Multifunction Steering Wheel Cruise Control
• 36 Oil Temperature Sensor
• 38 Air Flow Meter HFM
• 42 ADS
• 44 AirCon Switch
• 45 DWA Signal
• 46 DDE Error
• 47 RPM Sensor
• 49 Signal to Instrument Cluster
• 52 Intake Air Temperature Sensor
• 56 Injection Pump Position Sensor
• 58 Injection Quantity
• 59 Boost Pressure Control
• 60 DDE Power Supply
• 63 Cruise Control Adjustment
• 64 DDE Error
• 66 Fuel Supply
• 67 Air Supply Deviation
• 100 Cruise Control Adjustment Fault
• 101 Boost Pressure Control Deviation
• 102 DDE Error
• 103 DDE Error
• 104 DDE Error
• 105 DDE Error
• 106 DDE Output Stage
• 108 Variant Coding
• 109 Variant Coding
• 110 AirCon Poor Operation
• 111 EEPROM checksum Injection Pump Adaptation
• 112 CAN Error - EGS Control Unit
• 113 CAN Error - ASC Control Unit
• 114 CAN Error - Instrument Cluster
« ตอบกลับ #8 เมื่อ: พฤษภาคม 02, 2013, 16:17:57 »
DDE 3
• 01 Fuel Quantity Regulator
• 03 Shut off Valve
• 08 Glow system
• 0A Delivery Control Deviation
• 10 DDE Power Supply
• 11 DDE Low Voltage
• 12 DDE Voltage Supply
• 13 DDE Main Relay
• 1A Brake Light Switch or Brake Light Test Switch
• 1B Electric Auxiliary Heater
• 1C Clutch Switch
• 1D Vehicle Speed Signal
• 23 Fuel Temperature Sensor
• 24 Oil Temperature Sensor
• 26 Air Flow Meter HFM
• 2D EWS
• 2E Injection Pump RPM Sensor
• 2F Crankshaft Sensor
• 34 Temperature Sensor
• 35 Coolant Temperature Sensor
• 36 Boost Pressure Sensor
• 40 DDE Error
• 41 Solenoid Shut off Valve
• 42 DDE Error -EEPROM or Coding
• 43 Injection Pump Control Unit
• 44 Solenoid Valve
• 45 DDE Error -CAN Control
• 46 Injection Pump Signal
• 47 RPM Sensor Synchronicity
• 48 Fuel Injection Regulation
• 49 RPM Sensor Injection Pump
• 50 Boost Actuator
• 52 ECU Ventilator Fault
• 56 Coolant Fan Fault
• 64 DDE Error
• 65 Boost Pressure Regulation
• 6B Atmospheric Pressure Sensor
• 72 CAN BUS
• 73 RPM Sensor Injection Pump
• 74 Air Flow Meter Signal
• 75 Alternator Load Signal
• 77 Ambient Temperature Sensor
• 78 Air Flow Meter Signal
• 85 Coolant Fan Fault
« ตอบกลับ #9 เมื่อ: พฤษภาคม 02, 2013, 16:18:12 »
DDE 4 and DDE 4.1
• 0100 Air Flow Sensor HFM
• 0105 Atmospheric Pressure Sensor
• 0110 Intake Air Temperature Sensor
• 0115 Coolant Temperature Sensor
• 0120 Pedal Position Sensor 1
• 0190 Rail Pressure Sensor
• 0200 Injector Cylinder 1
• 0201 Injector Cylinder 5
• 0202 Injector Cylinder 3
• 0203 Injector Cylinder 6
• 0204 Injector Cylinder 2
• 0205 Injector Cylinder 4
• 0220 Pedal Position Sensor 2
• 0235 Boost Pressure Sensor
• 0335 Crankshaft RPM
• 03E6 Exhaust Gas Recirculation Regulation
• 0400 Exhaust Gas Recirculation
• 0404 Exhaust Gas Recirculation 2
• 0480 Electric ECU Fan
• 0500 Vehicle Speed Sensor Signal
• 0560 Internal Reference Voltage
• 0600 DDE Error CAN Controller
• 0605 DDE Error
• 1190 Rail Pressure Regulation
• 1195 Rail Pressure Sensor
• 1250 Delivery Pump Relay
• 1255 Delivery Pump Pressure Sensor
• 1260 Delivery Pump Control System
• 1470 Boost Pressure Regulation
• 1612 DME Incorrectly Coded
• 1613 MAP Control
• 1640 DDE Error EEPROM or Coding
• 1A04 Aux. Heater
• 1DF0 Engine Stall
• 1DF5 EWS - Timeout
• 1E00 CAN Communication to ASC
• 1E05 Vehicle Speed Sensor
• 1E25 RPM Regulation
• 1E30 Boost Pressure Regulation or Actuator
• 1E31 Boost Pressure Regulation
• 1E35 Error During Switch off
• 1E40 A/D Converter
• 1E45 Capacitor Voltage 1 for Cyl 1, 2, 3
• 1E50 Capacitor Voltage 2 for Cyl 4, 5, 6
• 1E55 RPM Control
• 1E60 Power Supply Pedal Sensor 1
• 1430 Boost Pressure or Actuator
• 2800 DDE Power Supply
• 3000 Brake Light or Brake Light Test Switch
• 3005 Voltage Supply KL15
• 3505 Glow Plug System
• 3506 Glow Plug System 2
• 3510 DDE Main Relay
• 3515 AirCon Power Output
• 3520 Engine Boost Actuation
• 3565 High Pressure Pump
• 3580 High Pressure Pump Shut Off Valve
• 3596 Brake Light Switch
• 3600 Atmospheric Pressure Sensor
• 3605 Air Flow Meter HFM 1 or 2
• 3610 Exhaust Gas Recirculation System
• 3615 Exhaust Gas Recirculation System -Regulation
• 3620 Air Flow Meter HFM Signal
« ตอบกลับ #10 เมื่อ: พฤษภาคม 02, 2013, 16:19:47 »
DDE 5, DDE 6, DDE 6.2 and DDE 6.3
• 3E90 Crankshaft RPM - No Signal
• 3E91 Crankshaft RPM - Wrong Signal
• 3E95 Intake air Temperature Sensor
• 3EA0 Crankshaft Position Sensor
• 3EA1 Crankshaft Position Sensor
• 3EA5 Intake air Temperature Sensor
• 3EA6 Intake air Temperature Sensor
• 3EB0 RPM Calculation
• 3EB5 Air flow Sensor 2
• 3EB6 Air flow Sensor 2
• 3EC0 Camshaft Sensor - No Signal
• 3EC1 Camshaft Sensor - Wrong Signal
• 3EC7 Camshaft Sensor
• 3ED0 Camshaft Sensor - No Signal
• 3ED1 Camshaft Sensor - Wrong Signal
• 3ED5 Air Flow Sensor 2
• 3ED6 Air Flow Sensor 2
• 3EDC Variant Coding
• 3EDD Variant Coding
• 3EE0 Coolant Temperature Sensor -Short Circuit to B+ or Open
• 3EE1 Coolant Temperature Sensor -Short Circuit to B-
• 3EE2 Coolant Temperature Sensor
• 3EE3 Coolant Temperature Sensor
• 3EE5 Air Mass Flow Sensor 2
• 3EE6 Air Mass Flow Sensor 2
• 3EE7 Air Mass Flow Sensor 2
• 3EED Power Management Closed Circuit Current
• 3EF3 Coolant Temperature Sensor not Plausible
• 3EF5 Intake Air Temperature Sensor 2 (HFM Reference Signal)
• 3EF6 Intake Air Temperature Sensor 2 (HFM Reference Signal)
• 3EF7 Intake Air Temperature Sensor 2 (HFM Reference Signal)
• 3EFB Thermal Oil Level Sensor
• 3EFC Thermal Oil Level Sensor
• 3EFD Thermal Oil Level Sensor
• 3F00 Boost Pressure Sensor -Short circuit to B+
• 3F01 Boost Pressure Sensor -Short circuit to B- or Open
• 3F02 Boost Pressure Sensor
• 3F03 Boost Pressure Sensor -Plausibility
• 3F05 MIL OFF
• 3F10 Pedal Position Sensor 1
• 3F11 Pedal Position Sensor 1 - Short circuit to B-
• 3F13 Pedal Position Sensor 1 - Potentiometer Plausibility
• 3F15 MIL ON
• 3F20 Pedal Position Sensor 2
• 3F21 Pedal Position Sensor 2 - Short Circuit to B-
• 3F23 Pedal Position Sensor 2 - Potentiometer Plausibility
• 3F25 Input Air Flow Control
• 3F30 Rail Pressure Sensor - Short Circuit to B+
• 3F31 Rail Pressure Sensor - Short Circuit to B-
• 3F35 Input Air Flow Control at Idle Speed
• 3F40 Rail Pressure Sensor - Max for Compensation
• 3F41 Rail Pressure Sensor - Min for Compensation
• 3F47 Brake Light or Brake Light Test Switch
• 3F48 Brake Light or Brake Light Test Switch
• 3F50 Vehicle Speed Signal - Too High
• 3F51 Vehicle Speed Signal
• 3F52 Vehicle Speed Signal
• 3F53 Vehicle Speed Signal
• 3F60 Pedal Position Sensor Ref. VSS
• 3F62 Vehicle Speed Signal from CAN
• 3F67 Filling Pressure Modulator 2
• 3F70 Intake Air Temperature Sensor
• 3F71 Intake Air Temperature Sensor
• 3F72 Intake Air Temperature Sensor
• 3F77 Boost Pressure Modulator 1
• 3F82 Ambient Temp Sensor
• 3F87 Boost Pressure Modulator 2
• 3F97 Boost Pressure Modulator 1
• 3FB0 Air Flow Meter - Signal too High or Short circuit to B+
• 3FB1 Air Flow Meter - Signal too Low or Short circuit to B-
• 3FB5 Control Master/Slave
• 3FB6 Control Master/Slave
• 3FB7 Control Unit - Internal Master
• 3FC0 Air Flow Meter - Deviation too High at Idle Speed
• 3FD0 Air Flow Meter - Deviation too High
• 3FE0 Air Flow Meter
• 3FE1 Air Flow Meter
• 3FF0 Air Flow Meter
• 3FF1 Air Flow Meter
• 4000 Fuel Temperature Sensor
• 4001 Fuel Temperature Sensor
• 4010 Exhaust Gas Pressure Sensor -Short Circuit to B+
• 4011 Exhaust Gas Pressure Sensor -Short Circuit to B-
• 4020 EGT -Short Circuit to B+
• 4021 EGT -Short Circuit to B-
• 4030 EGT Before Cat -Short Circuit to B+
• 4031 EGT Before Cat -Short Circuit to B-
• 4032 Exhaust Gas Pressure Sensor
• 4060 Atmospheric Pressure Sensor DDE-Short Circuit to B+
• 4061 Atmospheric Pressure Sensor DDE-Short Circuit to B-
• 4062 Atmospheric Pressure Sensor DDE
• 4063 Atmospheric Pressure Sensor DDE-Plausibility Ref. Boost
• 4072 Automatic Gearbox Switch Signal
• 4080 Brake Light or Brake Light Test Switch
• 4082 Brake Light or Brake Light Test Switch
• 4083 Brake Light or Brake Light Test Switch
• 40A1 Alternator Signal
• 40E0 Alternator
• 4100 AirCon Power Output
• 4101 AirCon Power Output
• 4102 AirCon Power Output
• 4103 AirCon Power Output
• 4108 Control Master/Slave
• 410C Swirl Flap Actuactor
• 4117 Control Master/Slave
• 4118 Control Master/Slave
• 4120 DDE Main Relay is Switching too Late or too Early
• 4121 DDE Main Relay is Switching too Late or too Early
• 4125 Power Supply
• 4126 Power Supply
• 4130 Swirlflaps - Short Circuit to B+
• 4135 Power Supply
• 4136 Power Supply
• 4140 Swirlflap
• 4141 Swirlflaps - Short Circuit to B-
• 4145 Power Supply
• 4146 Power Supply
• 4152 Swirlflaps - Open Circuit
• 4153 Swirlflaps - Plausibility, Overtemp of Output Stage
• 4155 Exhaust Flap Actuator
• 4156 Exhaust Flap Actuator
• 4157 Exhaust Flap Actuator
• 4158 Exhaust Flap Actuator
• 4160 Raise Pressure Pump - Short Circuit to B+
• 4161 Raise Pressure Pump - Short Circuit to B-
• 4162 Raise Pressure Pump - Activation Interrupted
• 4163 Raise Pressure Pump - Plausibility, Overtemp of Output Stage
• 4165 DPF -Flow Resistance too High
• 4166 DPF -Flow Resistance too Low
• 4175 Exhaust Gas Temp Sensor before DPF
• 4180 Boost Pressure Actuator - Short Circuit to B+
• 4185 Exhaust Gas Temp Sensor before Cat
• 4186 Exhaust Gas Temp Sensor before Cat
• 4188 Exhaust Gas Temp Sensor before Cat
• 4190 Boost Pressure Actuator
• 4191 Boost Pressure Actuator - Short Circuit to B-
• 419A Atmospheric Pressure Sensor DDE
• 419B Atmospheric Pressure Sensor DDE
• 41A0 Boost Pressure Actuator
• 41A1 Boost Pressure Actuator - Adjustment
• 41A2 Boost Pressure Actuator - Open Circuit
• 41A3 Boost Pressure Actuator - Plausibility, Overtemp of Output Stage
• 41A6 Message CBS Reset
• 41A7 Message CBS Reset
• 41AA Boost Pressure Sensor
• 41AB Boost Pressure Sensor
• 41B0 Exhaust Gas Recirculation -Short Circuit to B+
• 41B5 Transmission Fluid Temperature Sensor
• 41BA Exhaust Backpressure Sensor
• 41BB Exhaust Backpressure Sensor
• 41C0 Activation -Fan
• 41C1 Activation -Fan- Short Circuit to B-
• 41C2 Activation -Fan- Activation Interrupted
• 41C3 Activation -Fan- Plausibility, Overtemp of Output Stage
• 41CD Exhaust Backpressure Sensor - Plausibility
• 41D0 Exhaust Gas Recirculation Regulation
• 41D1 Exhaust Gas Recirculation -Short Circuit to B-
• 41D5 Lambda Sensor Bias -Short Circuit to B+
• 41D6 Lambda Sensor Bias -Short Circuit to B-
• 41D7 Lambda Sensor Bias -Open Circuit
• 41E0 Exhaust Gas Recirculation Regulation
• 41E2 Exhaust Gas Recirculation - Open Circuit
• 41E3 Exhaust Gas Recirculation -Plausibility, Overtemp of Output Stage
• 41E5 Lambda Sensor -Short Circuit to B+
• 41E6 Lambda Sensor -Short Circuit to B-
• 41E7 Lambda Sensor -Open Circuit
• 41F0 Electric Ventilator - Short Circuit to B+
• 41F1 Electric Ventilator - Short Circuit to B-
• 41F2 Electric Ventilator - Activation Interrupted
• 41F3 Electric Ventilator - Plausibility, Overtemp of Output Stage
• 41F5 Lambda Sensor Virtual Earth -Short Circuit to B+
• 41F6 Lambda Sensor Virtual Earth -Short Circuit to B-
• 41F7 Lambda Sensor Virtual Earth -Open Circuit
• 4203 Glow Module Communication
• 4205 Lambda Sensor Heating -Short Circuit to B+
• 4206 Lambda Sensor Heating -Short Circuit to B-
• 4207 Lambda Sensor Heating
• 420B EGR in Regen Mode
• 4211 Glow Plug Cyl 1 - Short Circuit to B+
• 4212 Glow Plug Cyl 1 - Activation Interrupted
• 4213 Glow Plug Cyl 1 - Plausibility, Overtemp of Output Stage
• 4217 Lambda Sensor
• 4221 Glow Plug Cyl 2 - Short Circuit to B+
• 4222 Glow Plug Cyl 2 - Activation Interrupted
• 4223 Glow Plug Cyl 2 - Plausibility, Overtemp of Output Stage
• 4225 Lambda Sensor -Signal
• 4226 Lambda Sensor -Signal too Low
• 422A EGR in Regen Mode
• 4231 Glow Plug Cyl 3 - Short Circuit to B+
• 4232 Glow Plug Cyl 3 - Activation Interrupted
• 4233 Glow Plug Cyl 3 - Plausibility, Overtemp of Output Stage
• 4235 Control Unit Internal 21
• 4236 Control Unit Internal 21
• 4241 Glow Plug Cyl 4 - Short Circuit to B+
• 4242 Glow Plug Cyl 4 - Activation Interrupted
• 4243 Glow Plug Cyl 4 - Plausibility, Overtemp of Output Stage
• 4245 Control Unit Internal 22
• 4246 Control Unit Internal 22
• 4251 Glow Plug Cyl 5 - Short Circuit to B+
• 4252 Glow Plug Cyl 5 - Activation Interrupted
• 4253 Glow Plug Cyl 5 - Plausibility, Overtemp of Output Stage
• 4258 Control Unit Internal 23
• 425D Accelerator Pedal Potentiometer Plausibility
• 4261 Glow Plug Cyl 6 - Short Circuit to B+
• 4262 Glow Plug Cyl 6 - Activation Interrupted
• 4263 Glow Plug Cyl 6 - Plausibility, Overtemp of Output Stage
• 4267 Lambda Sensor Shunt Detection
• 4271 Glow Plug Cyl 7 - Short Circuit to B+
• 4272 Glow Plug Cyl 7 - Activation Interrupted
• 4273 Glow Plug Cyl 7 - Plausibility, Overtemp of Output Stage
• 4275 Lambda Sensor Heater
• 4276 Lambda Sensor Heater
• 4281 Glow Plug Cyl 8 - Short Circuit to B+
• 4282 Glow Plug Cyl 8 - Activation Interrupted
• 4283 Glow Plug Cyl 8 - Plausibility, Overtemp of Output Stage
• 4288 Lambda Sensor Heater
• 428B Boost Pressure Control of Large Turbo Control Deviation
• 4293 Control Unit Internal Error 16
• 4296 Lambda Sensor
• 4298 Lambda Sensor
• 429A Boost Pressure Control of Large Turbo Control Deviation
• 42B5 RPM Control
• 42C0 Oil Pressure Indicator Lamp - Short Circuit to B+
• 42C1 Oil Pressure Indicator Lamp - Short Circuit to B-
• 42C2 Oil Pressure Indicator Lamp - Activation interrupted
• 42C3 Oil Pressure Indicator Lamp - Plausibility, Overtemp of Output Stage
• 42D5 Injector Cylinder 7
• 42D6 Injector Cylinder 7
• 42D7 Injector Cylinder 7
• 42D8 Injector Cylinder 7
• 42E2 Changeover Rail Pressure Control
• 42F2 Changeover Rail Pressure Control
• 42F5 Injector Cylinder 8
• 42F6 Injector Cylinder 8
• 42F7 Injector Cylinder 8
• 42F8 Injector Cylinder 8
• 4302 Quantity Regulation Valve - Activation interrupted
• 4303 Quantity Regulation Valve - Plausibility, Overtemp of Output Stage
• 4310 Quantity Regulation Valve - Short Circuit to B+
• 4321 Quantity Regulation Valve - Short Circuit to B-
• 4332 Rail Pressure Regulation Valve - Activation Interrupted
• 4333 Rail Pressure Regulation Valve - Plausibility, Overtemp of Output Stage
• 4340 Rail Pressure Regulation Valve - Short Circuit to B+
• 4351 Rail Pressure Regulation Valve - Short Circuit to B-
• 4360 Rail Pressure Regulation Valve - Current Regulation
• 4361 Rail Pressure Regulation Valve - Current Regulation
• 4362 Rail Pressure Regulation Valve - Current Regulation
• 4373 Air Flow Mass not Plausible
• 4378 Rail Pressure Regulation Valve - Defect
• 4382 Rail Pressure Valve Position Test
• 4390 Boost Air Temperature Sensor - Short Circuit to B+
• 4391 Boost Air Temperature Sensor - Short Circuit to B-
• 4392 Boost Air Temperature Sensor
• 4397 Position Test Volume Adjust Valve
• 43A0 Start-block Relay
• 43A1 Start-block Relay
• 43A2 Start-block Relay
• 43A3 Start-block Relay
• 43C0 Throttle Valve Actuator -Short Circuit to B+
• 43D1 Throttle Valve Actuator -Short Circuit to B-
• 43E2 Throttle Valve Actuator -Open Circuit
• 43E3 Throttle Valve Actuator -Plausibility, Overtemp of Output Stage
• 43F0 Electrical Aux Heater - Short Circuit to B+
• 43F1 Electrical Aux Heater - Short Circuit to B-
• 43F2 Electrical Aux Heater - Activation Interrupted
• 43F3 Electrical Aux Heater - Plausibility, Overtemp of Output Stage
• 4403 Control Unit Internal Error 17
• 4410 Injector Cylinder 1- Activation
• 4411 Injector Cylinder 1- Activation
• 4412 Injector Cylinder 1- Activation
• 4413 Injector Cylinder 1- Activation
• 4417 Control Master/Slave
• 441C Injector Cylinder 1 - Earth Side Activation or Open Circuit
• 4420 Injector Cylinder 2- Activation
• 4421 Injector Cylinder 2- Activation
• 4422 Injector Cylinder 2- Activation
• 4423 Injector Cylinder 2- Activation
• 4428 Control Master/Slave
• 442C Injector Cylinder 2 - Earth Side Activation or Open Circuit
• 4430 Injector Cylinder 3- Activation
• 4431 Injector Cylinder 3- Activation
• 4432 Injector Cylinder 3- Activation
• 4433 Injector Cylinder 3- Activation
• 4438 Control Master/Slave
• 443C Injector Cylinder 3 - Earth Side Activation or Open Circuit
• 4440 Injector Cylinder 4- Activation
• 4441 Injector Cylinder 4- Activation
• 4442 Injector Cylinder 4- Activation
• 4443 Injector Cylinder 4- Activation
• 444C Injector Cylinder 4 - Earth Side Activation or Open Circuit
• 4450 Injector Cylinder 5- Activation
• 4451 Injector Cylinder 5- Activation
• 4452 Injector Cylinder 5- Activation
• 4453 Injector Cylinder 5- Activation
• 445C Injector Cylinder 5 - Earth Side Activation or Open Circuit
• 4460 Injector Cylinder 6- Activation
• 4461 Injector Cylinder 6- Activation
• 4462 Injector Cylinder 6- Activation
• 4463 Injector Cylinder 6- Activation
• 446C Injector Cylinder 6 - Earth Side Activation or Open Circuit
• 4473 Control Unit Internal Error 18
• 4480 Control Unit Internal Error 19
• 4491 Control Unit Internal Error 20
• 44A0 Injectors: Activation Cylinder. 1, 2, 3
• 44A1 Injectors: Activation Cylinder. 1, 2, 3
• 44A3 Injectors: Activation Cylinder. 1, 2, 3
• 44AC Injectors: Activation Cylinder. 1, 2, 3
• 44B0 Injectors: Activation Cylinder. 1, 2, 3
• 44B1 Injectors: Activation Cylinder. 4, 5, 6
• 44B3 Injectors: Activation Cylinder. 4, 5, 6
• 44BC Injectors: Activation Cylinder. 4, 5, 6
• 44C0 Number of Requested Injections Limited
• 44C1 Number of Requested Injections Limited
• 44C2 Number of Requested Injections Limited
• 44D0 Alternator
• 44D2 Alternator
• 44D3 Alternator
• 44E2 Alternator
• 44E3 Alternator
• 44F0 Rail Pressure not Plausible
• 4500 Exhaust Gas Recirculation- Deviation
• 4501 Exhaust Gas Recirculation- Negative Deviation or Air Mass too High
• 4506 Exhaust Gas Recirculation- Deviation
• 4507 Exhaust Gas Recirculation- Posative Deviation or Air Mass too Low
• 4512 Thermal Oil Level Sensor
• 4513 Thermal Oil Level Sensor
• 4521 Boost Pressure Actuator - Regulation Pressure too High
• 452A DPF System
• 4530 Boost Pressure Actuator - Regulation Pressure too Low
• 4536 Power Management
• 453B PT Can Bus
• 453C PT Can Bus
• 453D PT Can Bus
• 4541 Thermal Oil Level Sensor
• 454B Private CAN bus(master)
• 454C Private CAN bus(master)
• 454D Private CAN bus(master)
• 4550 Boost Pressure Modulation 2
• 4560 Rail Pressure Sensor - Plausibility -Pressure too Low
• 4570 Rail Pressure not Plausible
• 4580 Rail Pressure Sensor - Plausibility -Pressure too High
• 4587 Fuel Filter
• 4590 Rail Pressure not Plausible
• 45A0 Rail Pressure Sensor - Plausibility -Pressure too High
• 45A5 Boost Air Temp Sensor 2- Signal
• 45A6 Boost Air Temp Sensor 2- Signal
• 45C0 Rail Pressure not Plausible
• 45E3 Control Master/Slave
• 45F2 Control Master/Slave
• 45F3 Control Master/Slave
• 4600 Rail Pressure Sensor - Plausibility -Pressure too Low
• 4605 DPF System
• 4610 Rail Pressure not Plausible
• 4618 DPF -Plausibility -Pressure Reference
• 4620 Rail Pressure Sensor - Plausibility -Pressure too High
• 4628 DPF System
• 4630 Rail Pressure not Plausible
• 4640 Rail Pressure not Plausible
• 4645 EGR Controller
• 4650 Rail Pressure not Plausible
• 4656 Control Unit Internal 24
• 4660 Power Supply
• 4661 Power Supply
• 4665 DPF Bank 1
• 4666 DPF Bank 1
• 4667 DPF Bank 1
• 4670 Power Supply 1 - Short Circuit to B+
• 4671 Power Supply 1 - Short Circuit to B-
• 4677 Throttle Valve Actuator
• 4680 Power Supply 2 - Short Circuit to B+
• 4681 Power Supply 2 - Short Circuit to B-
• 4687 Throttle Valve Actuator
• 4690 Power Supply
• 4691 Power Supply
• 4697 Throttle Valve Actuator
• 46A0 Control Unit Internal Error 1
• 46A1 Control Unit Internal Error 1
• 46A2 Control Unit Internal Error 1
• 46A3 Control Unit Internal Error 1
• 46A7 Swirl Flap Actuator
• 46B0 Control Unit Internal Error 2
• 46B1 Control Unit Internal Error 2
• 46B2 Control Unit Internal Error 2
• 46B3 Control Unit Internal Error 2
• 46B7 Swirl Flap Actuator
• 46C0 Control Unit Internal Error 3
• 46C1 Control Unit Internal Error 3
• 46C2 Control Unit Internal Error 3
• 46C3 Control Unit Internal Error 3
• 46C7 Swirl Flap Actuator
• 46D0 Control Unit Internal Error 4
• 46D1 Control Unit Internal Error 4
• 46D2 Control Unit Internal Error 4
• 46D3 Control Unit Internal Error 4
• 46D5 Compressor Bypass Activation
• 46D6 Compressor Bypass Activation
• 46D7 Compressor Bypass Activation
• 46D8 Compressor Bypass Activation
• 46E0 Control Unit Internal Error 5
• 46E1 Control Unit Internal Error 5
• 46E2 Control Unit Internal Error 5
• 46E3 Control Unit Internal Error 5
• 46E5 Wastegate Valve Activation
• 46E6 Wastegate Valve Activation
• 46F0 Control Unit Internal Error 6
• 46F1 Control Unit Internal Error 6
• 46F2 Control Unit Internal Error 6
• 46F3 Control Unit Internal Error 6
(ต่อด้านล่าง)
Re: รายละเอียด รหัสโค๊ตต่างๆ ครับผม
« ตอบกลับ #11 เมื่อ: พฤษภาคม 02, 2013, 16:20:07 »
(ต่อจากด้านบน)
• 4700 Control Unit Internal Error 7
• 4701 Control Unit Internal Error 7
• 4702 Control Unit Internal Error 7
• 4703 Control Unit Internal Error 7
• 4707 Wastegate Valve Activation
• 4708 Wastegate Valve Activation
• 4710 Control Unit Internal Error 8
• 4711 Control Unit Internal Error 8
• 4712 Control Unit Internal Error 8
• 4713 Control Unit Internal Error 8
• 4720 Control Unit Internal Error 9
• 4721 Control Unit Internal Error 9
• 4722 Control Unit Internal Error 9
• 4723 Control Unit Internal Error 9
• 4730 Quantity Regulation Current Regulation
• 4731 Quantity Regulation Current Regulation
• 4732 Quantity Regulation Current Regulation
• 4740 Control Unit Internal Error 11
• 4747 Injectors - Amplifier Adjustment(control unit internal)
• 4750 Control Unit Internal Error 12
• 4753 Control Unit Internal Error 12
• 475A Exhaust Backpressure Sensor- Bank 2
• 475B Exhaust Backpressure Sensor- Bank 2
• 4763 Control Unit Internal Error 13
• 4765 Injector Cyl 1 - Activation
• 4766 Injector Cyl 1 - Activation
• 4767 Injector Cyl 1 - Activation
• 4768 Injector Cyl 1 - Activation
• 476A Injector Cyl 4/5/6 Buffer Voltage Measurement(control unit internal)
• 476B Injector Cyl 4/5/6 Buffer Voltage Measurement(control unit internal)
• 4770 Control Unit Internal Error 14
• 4771 Control Unit Internal Error 14
• 4772 Control Unit Internal Error 14
• 4773 Control Unit Internal Error 14
• 477C Injectors Activation Duration(control unit internal)
• 4780 Control Unit Internal Error 15
• 4781 Control Unit Internal Error 15
• 4782 Control Unit Internal Error 15
• 4783 Control Unit Internal Error 15
• 4785 Injector Cyl 2 - Activation
• 4786 Injector Cyl 2 - Activation
• 4787 Injector Cyl 2 - Activation
• 4788 Injector Cyl 2 - Activation
• 478C Injector Activation Duration(control unit internal)
• 4792 Monitoring Master/Slave
• 4793 Monitoring Master/Slave
• 4795 Injector Cyl 3 - Activation
• 4796 Injector Cyl 3 - Activation
• 4797 Injector Cyl 3 - Activation
• 4798 Injector Cyl 3 - Activation
• 47A5 Injector Cyl 4 - Activation
• 47A6 Injector Cyl 4 - Activation
• 47A7 Injector Cyl 4 - Activation
• 47A8 Injector Cyl 4 - Activation
• 47AB Private CAN Bus(Slave)
• 47AC Private CAN Bus(Slave)
• 47AD Private CAN Bus(Slave)
• 47B5 Injector Cyl 5 - Activation
• 47B6 Injector Cyl 5 - Activation
• 47B7 Injector Cyl 5 - Activation
• 47B8 Injector Cyl 5 - Activation
• 47BB Power Train CAN Bus(Slave)
• 47BC Power Train CAN Bus(Slave)
• 47BD Power Train CAN Bus(Slave)
• 47C5 Injector Cyl 6 - Activation
• 47C6 Injector Cyl 6 - Activation
• 47C7 Injector Cyl 6 - Activation
• 47C8 Injector Cyl 6 - Activation
• 47D5 Injector Cyl 7 - Activation
• 47D6 Injector Cyl 7 - Activation
• 47D7 Injector Cyl 7 - Activation
• 47D8 Injector Cyl 7 - Activation
• 47E5 Injector Cyl 8 - Activation
• 47E6 Injector Cyl 8 - Activation
• 47E7 Injector Cyl 8 - Activation
• 47E8 Injector Cyl 8 - Activation
• 4803 Torque Control ACC
• 480A DPF -Bank 1
• 4810 Torque Control ACC
• 481A DPF -Bank 1
• 4830 Intake Air Temperature Sensor
• 4831 Intake Air Temperature Sensor
• 483D Throttle Actuator
• 4841 Exhaust Gas Recirculation Regulation 2
• 484A Accelerator Pedal Potentiometer -Signal
• 4850 Exhaust Gas Recirculation Regulation 2
• 4857 Swirl Flap Actuator
• 4863 Vehicle Speed Regulation
• 4867 Swirl Flap Actuator
• 486D Control Unit Software Fault
• 4877 Swirl Flap Actuator
• 487A Lambda Sensor Bank 2 - Bias Voltage
• 487B Lambda Sensor Bank 2 - Bias Voltage
• 487C Lambda Sensor Bank 2 - Bias Voltage
• 4887 Swirl Flap Actuator
• 488A Lambda Sensor Bank 2 - Pump Current
• 488B Lambda Sensor Bank 2 - Pump Current
• 488C Lambda Sensor Bank 2 - Pump Current
• 4896 Swirl Flap Actuator
• 489A Lambda Sensor Bank 2 - Virtual Ground
• 489B Lambda Sensor Bank 2 - Virtual Ground
• 489C Lambda Sensor Bank 2 - Virtual Ground
• 48A2 CAN Communication with ASC
• 48A3 CAN Communication with ASC
• 48B2 CAN Communication with ASC
• 48B3 CAN Communication with ASC
• 48B5 Injectors Voltage Measurement(control unit internal)
• 48B6 Injectors Voltage Measurement(control unit internal)
• 48B7 Injectors Voltage Measurement(control unit internal)
• 48BC Lambda Sensor Bank 2
• 48C2 CAN Communication with EGS
• 48C5 Injectors Voltage Measurement(control unit internal)
• 48C6 Injectors Voltage Measurement(control unit internal)
• 48C7 Injectors Voltage Measurement(control unit internal)
• 48CA Lambda Sensor Bank 2
• 48CB Lambda Sensor Bank 2
• 48D2 CAN Communication with Instrument Cluster
• 48D3 CAN Communication with Instrument Cluster
• 48DA Control Unit Internal 25
• 48DB Control Unit Internal 25
• 48EA Control Unit Internal 26
• 48EB Control Unit Internal 26
• 48F2 CAN BUS Hardware
• 48F3 CAN BUS Hardware
• 48F7 Injectors Wiring Loom
• 48FD Control Unit Internal 27
• 4900 DSC Torque Intervention
• 4907 Injectors Selector Switch(control unit internal)
• 490B Control Unit Internal 28
• 4912 CAN BUS Hardware Defect in Operation
• 4913 CAN BUS Hardware Fault in Initialisation
• 4917 Injectors Charge Switch(control unit internal)
• 4920 Transmission Link
• 4925 Throttle Valve Actuator 2 Activation
• 492A Lambda Sensor Bank 2 Heater
• 492B Lambda Sensor Bank 2 Heater
• 4936 Throttle Valve Actuator 2 Activation
• 493D Lambda Sensor Bank 2
• 4947 Throttle Valve Actuator 2 Activation
• 4948 Throttle Valve Actuator 2 Activation
• 494D Lambda Sensor Bank 2
• 4957 Throttle Valve Actuator 2
• 495A Exhaust Temp Sensor before DPF Bank 2
• 495B Exhaust Temp Sensor before DPF Bank 2
• 4967 Throttle Valve Actuator 2
• 496A DPF Bank 2
• 497A DPF Bank 2
• 4991 Message : Instrument Cluster
• 4992 Message : Instrument Cluster
• 4997 Throttle Valve Actuator 2
• 49A2 Message : Ambient Temperature
• 49B0 Message : Torque Request
• 49C0 Message : Torque Request
• 49D2 Message : Torque Request
• 49E0 Message : Torque Request
• 49E7 Throttle Actuator
• 49F2 Message : Vehicle Speed
• 49F3 Message : Vehicle Speed
• 4A02 Terminal 15
• 4A03 Terminal 15
• 4A07 Alternator
• 4A08 Alternator
• 4A10 BSD Interface
• 4A13 BSD Interface
• 4A15 Alternator
• 4A17 Alternator
• 4A18 Alternator
• 4A22 Boost Air Pressure Actuator 2 Activation
• 4A23 Boost Air Pressure Actuator 2 Activation
• 4A25 Intelligent Battery Sensor
• 4A27 Intelligent Battery Sensor
• 4A28 Intelligent Battery Sensor
• 4A30 Multifunction Steering Wheel- Toggle Bit
• 4A31 Multifunction Steering Wheel- Frequency Counter
• 4A32 Multifunction Steering Wheel- No Signal
• 4A33 Multifunction Steering Wheel- Signal not Plausible
• 4A35 Intelligent Battery Sensor
• 4A37 Intelligent Battery Sensor
• 4A38 Intelligent Battery Sensor
• 4A41 EWS Interface
• 4A42 EWS Interface
• 4A43 EWS Interface
• 4A45 Intelligent Battery Sensor
• 4A47 Intelligent Battery Sensor
• 4A48 Intelligent Battery Sensor
• 4A50 EWS Code Storage
• 4A51 EWS Code Storage
• 4A56 Power Management Battery
• 4A58 Power Management Battery
• 4A60 EWS Manipulation
• 4A61 EWS Manipulation
• 4A62 EWS Manipulation
• 4A63 EWS Manipulation
• 4A65 Power Management Vehicle Electrical System
• 4A66 Power Management Vehicle Electrical System
• 4A67 Power Management Vehicle Electrical System
• 4A70 Reference Values Incorrect
• 4A80 Intake Air Hose
• 4AA2 CAN Communication with EGS
• 4AA3 CAN Communication with EGS
• 4AB0 Electrical Aux Heater
• 4AD5 Zero Quantity Adaptation Injector 1
• 4AD6 Zero Quantity Adaptation Injector 1
• 4AE0 E-Box Ventilator -Short circuit to B+
• 4AE1 E-Box Ventilator -Short circuit to B-
• 4AE2 E-Box Ventilator -Activation Interrupted
• 4AE3 E-Box Ventilator -Plausibility, Overtemp of Output Stage
• 4AE5 Zero Quantity Adaptation Injector 2
• 4AE6 Zero Quantity Adaptation Injector 2
• 4AF0 Control Unit Temperature Sensor
• 4AF1 Control Unit Temperature Sensor
• 4AF5 Zero Quantity Adaptation Injector 3
• 4AF6 Zero Quantity Adaptation Injector 3
• 4B00 Control Unit Temperature
• 4B05 Zero Quantity Adaptation Injector 4
• 4B06 Zero Quantity Adaptation Injector 4
• 4B10 Smooth Running Regulation -Correction Quantity too High
• 4B11 Smooth Running Regulation -Correction Quantity too Low
• 4B15 Zero Quantity Adaptation Injector 5
• 4B16 Zero Quantity Adaptation Injector 5
• 4B20 Electro ventilator -Blocked
• 4B22 Electro Ventilator
• 4B25 Zero Quantity Adaptation Injector 6
• 4B26 Zero Quantity Adaptation Injector 6
• 4B35 Oil Sensor
• 4B36 Oil Sensor
• 4B37 Oil Sensor
• 4B38 Oil Sensor
• 4B45 Injector Cyl 1 Energy Consumption Measurement
• 4B50 Quantity Compensation
• 4B55 Injector Cyl 2 Energy Consumption Measurement
• 4B60 Quantity Compensation
• 4B65 Injector Cyl 3 Energy Consumption Measurement
• 4B75 Injector Cyl 4 Energy Consumption Measurement
• 4B80 Rail Pressure not Plausible
• 4B85 Injector Cyl 5 Energy Consumption Measurement
• 4B90 Rail Pressure Control at Engine Start
• 4B95 Injector Cyl 6 Energy Consumption Measurement
• 4BA0 Intake Air Temperature Sensor -Signal too High or Short
• 4BA1 Intake Air Temperature Sensor -Signal too Low
• 4BB0 Air Flow Sensor Power Supply
• 4BB1 Air Flow Sensor Power Supply
• 4BB5 Air Flow Meter -Signal too Low
• 4BB6 Air Flow Meter -Signal too High
• 4BC0 Air Flow Meter -Signal too Low
• 4BC1 Air Flow Meter -Signal too High
• 4BC2 Air Flow Meter -Short Circuit
• 4BC5 Intake Air Temperature Sensor
• 4BC6 Intake Air Temperature Sensor
• 4BC7 Intake Air Temperature Sensor
• 4BD2 ARS Torque Request
• 4BD5 Engine Support
• 4BD6 Engine Support
• 4BD7 Engine Support
• 4BD8 Engine Support
• 4BE2 Message : Transmission data
• 4BE7 Message : Transmission data 2
• 4BF2 Message : Air Conditioning
• 4BF7 Message : Range
• 4C00 Message : Cruise Control
• 4C01 Message : Cruise Control
• 4C02 Message : Cruise Control
• 4C06 Message : ARS Status
• 4C07 Message : ARS Status
• 4C12 Message : DSC Status
• 4C15 Message : Terminal 15
• 4C16 Message : Terminal 15
• 4C17 Message : Terminal 15
• 4C20 Message : DSC Torque
• 4C21 Message : DSC Torque
• 4C22 Message : DSC Torque
• 4C23 Message : DSC Torque
• 4C27 Message : Vehicle Speed
• 4C28 Message : Vehicle Speed
• 4C45 Injector Cyl 7 Energy Consumption Measurement
• 4C55 Injector Cyl 8 Energy Consumption Measurement
• 4C65 Zero Quantity Adaptation Injector 7
• 4C66 Zero Quantity Adaptation Injector 7
• 4C75 Supply Voltage Air Mass Flow Sensor 2
• 4C76 Supply Voltage Air Mass Flow Sensor 2
• 4C95 Zero Quantity Adaptation Injector 8
• 4C96 Zero Quantity Adaptation Injector 8
• 4CA2 Message : Power Management
• 4CB2 Message : Power Management
• 4CB3 Message : Power Management
• 4CF3 DPF -Plausibility -Exhaust Gas Pressure
• 4D00 Exhaust Backpressure Sensor Bank 1
• 4D03 Exhaust Backpressure Sensor Bank 1
• 4D25 Exhaust Temp Sensor before Catalytic Converter Bank 2
• 4D26 Exhaust Temp Sensor before Catalytic Converter Bank 2
• 4D45 Exhaust Temp Sensor before DPF Bank 2
• 4D46 Exhaust Temp Sensor before DPF Bank 2
• 4D56 DPF Bank 2
• 4D65 DPF System
• 4D75 DPF System
• 4D81 Boost Pressure Actuator 2 Activation
• 4D98 Exhaust Backpressure Sensor Bank 2
• 4DA3 Boost Pressure Control
• 4DA5 Exhaust Backpressure Sensor Bank 2
• 4DA8 Exhaust Backpressure Sensor Bank 2
• 4DB0 EGR Controller 2 Activation
• 4DC1 EGR Controller 2 Activation
• 4DD2 EGR Controller 2 Activation
• 4DD3 EGR Controller 2 Activation
• 4DD5 Exhaust Temp Sensor before DPF Bank 2
• 4DE0 Monitoring Master/Slave - Private CAN
• 4DE1 Monitoring Master/Slave - Private CAN
• 4DE3 Monitoring Master/Slave - Private CAN
• 4DF0 Message : Transmission Torque
• 4DF1 Message : Transmission Torque
• 4DF2 Message : Transmission Torque
• 4DF3 Message : Transmission Torque
• 4DF5 Exhaust Temp Sensor before DPF Bank 2
• 7073 Automatic Gearbox Switch Signal
• CD87 CAN Bus Communication Error
• CD8B CAN Bus -Control Module has Left the Bus
Re: รายละเอียด รหัสโค๊ตต่างๆ ครับผม สำหรับ DIS
« ตอบกลับ #12 เมื่อ: พฤษภาคม 02, 2013, 16:21:39 »
Body Modules
ABS 1
• 1 ABS Hydraulic Unit
• 2 TPS
• 3 Ignition Timing Error
• 4 Rear Left Speed Sensor or ABS Inlet Valve
• 5 Rear Right Speed Sensor or ABS Inlet Valve
• 6 Front Right Speed Sensor or ABS Inlet Valve
• 7 Front Left Speed Sensor or ABS Inlet Valve
• 8 Rear Left ABS Valve
• 9 Rear Right ABS Valve
• 10 Front Right ABS Valve
• 11 Front Left ABS Valve
• 12 EGS Intervention
• 13 Idle Speed RPM Increasing
• 14 Valve Relay Fault
• 15 ABS Delivery Pump Fault
• 16 Throttle Valve Reduction
• 17 Front Left Wheel Sensor
• 18 Front Left Wheel Sensor
• 19 Accumulator -Pressure Limit
• 20 Front Left Wheel Sensor or EGS-Intervention Error
• 21 Front Left Wheel Sensor or ABS/ASC ECU Fault
• 22 Speed Sensor Signal
• 23 Equipment ERROR (Automatic/Manual)
• 24 Incorrect Pulse Generator
• 25 Brake Light Switch
• 27 Idle Speed Signal
• 30 Left Rear Wheel Speed Sensor Cable
• 31 Right Rear Wheel Speed Sensor Cable
• 32 Right Front Wheel Speed Sensor Cable
• 33 Left Front (E38/E39) or Right (E46) Wheel Speed Sensor Cable
• 34 Front Right Wheel Sensor or ASC Switch Over Valve
• 35 Brake Fluid Level Signal
• 36 Front Right Wheel Sensor or Ignition Signal Error
• 37 Front Right Wheel Sensor or ABS/ASC Control Unit -Internal Error
• 38 Gas Valve Adjustment Error
• 39 Servo Motor - Electrical Error
• 40 Gas Valve - Potentiometer Error
• 41 Steering Angle Sensor Error
• 47 Outlet Valve - Rear Left
• 48 Outlet Valve - Rear Right
• 49 Wheel Sensor - Rear Left or Outlet Valve - Front Right
• 50 Wheel Sensor - Rear Left or Outlet Valve - Front Left
• 51 Inlet Valve - Rear Left
• 52 Wheel Sensor - Rear Left or Inlet Valve - Rear Right
• 53 Wheel Sensor - Rear Left or Inlet Valve - Front Right
• 54 Inlet Valve - Front Left
• 55 ASC Shutoff Valve
• 56 CAN ERROR (Short Circuit)
• 57 Throttle Valve Signal from DME
• 58 CAN ERROR (Open Circuit)
• 59 ASC Shutoff Valve
• 60 Signal Fault - Pin 30
• 61 Central Wheel-Blocking
• 62 Max Anti Blocking Adjustment Time
• 63 Processor Fault ECU
• 64 Continuous Control due to Undefined Signal Interference
• 65 Wheel Sensor - Rear Right or Feedback Signal
• 66 Wheel Sensor - Rear Right or Wheel Speed Sensor Power Supply
• 67 CAN ERROR
• 68 Wheel Sensor - Rear Right
• 69 Wheel Sensor - Rear Right
• 70 Error 70
• 75 ASC Indication Lamp
• 81 Inlet Valve Front Left
• 82 Inlet Valve Front Right
• 83 Inlet Valve Rear Left
• 84 Inlet Valve Rear Right
• 85 Outlet Valve Front Left
• 86 Outlet Valve Front Right
• 87 Outlet Valve Rear Left
• 88 Outlet Valve Rear Right
• 89 Power Supply Low
• 90 TimeOut - Passive Switching
• 91 CAN ERROR
• 92 Pressure Sensor Pre Charge Pump
• 94 RPM Sensor (Test)
• 95 Activation
• 96 Actuator Test
• 97 ASC Intake Valve / Steering Angle Sensor
• 98 Separate Valve
• 99 Electro Magnetic Switch Over Valve
• 100 Electro Magnetic Switch Over Valve
• 103 Brake Light Switch
• 104 Steering Angle Sensor
• 105 Brake Light Switch
• 106 Lateral Acceleration Sensor
• 107 RPM sensor (Gradient)
• 113 ABS /ASC Feed Back Pump
• 115 ABS/ASC Control Unit - Internal Error
• 118 Electromagnetic or Mechanical Interference -Wheel Speed Signals
• 120 Power Supply too High (> 18V)
• 129 ABS/ASC Main Relay Circuit
• 130 Power Supply - Solenoid Valves
• 131 Wrong Current - Solenoid Valves
• 133 Power Supply - too High
• 145 CAN chip in the ABS/ASC control unit
• 146 CAN ERROR
• 147 CAN ERROR - Engine Intervention
• 148 CAN ERROR - Engine speed (RPM)
• 149 CAN ERROR - DME/DDE connection
• 150 CAN ERROR - EGS
• 151 Coding Error
• 152 DSC Button
• 161 RPM Sensor
• 162 RPM Signal
• 163 Lateral Acceleration Sensor
• 164 Lateral Acceleration Sensor
• 165 Pressure Sensor 1
• 166 Pressure Sensor 2
• 167 Pressure Sensors
• 168 Pressure Sensors Power Supply
• 177 Pre Charge Pump
• 178 Pre Charge Pump
• 180 Steering Angle Sensor -Signal 1
• 181 Steering Angle Sensor -Identification
• 182 Steering Angle Sensor -CAN
• 183 Steering Angle Sensor -Internal
• 184 Steering Angle Sensor -Offset
ABS 2
• 2 EML Interface Fault
• 3 DME Interface Fault
• 4 Sensor Fault Rear Left
• 5 Sensor Fault Rear Right
• 6 Sensor Fault Front Right
• 7 Sensor Fault Front Left
• 8 ABS Valve Fault Rear Left
• 9 ABS Valve Fault Rear Right
• 10 ABS Valve Fault Front Right
• 11 ABS Valve Fault Front Left
• 12 Solenoid Valve Fault Rear Left
• 13 Solenoid Valve Fault
• 14 ABS Valve Relay Fault
• 15 Rear Feed Pump Fault
• 16 ASC+T Storage Valve Fault
• 17 Wheel Sensor / Inlet Valve Front Left
• 18 Wheel Sensor / Outlet Valve Front Left
• 20 Wheel Sensor / Inlet Valve Front Right
• 24 Wheel Sensor / Outlet Valve Front Right
• 33 Wheel Sensor / Inlet Valve Rear Left
• 34 Wheel Sensor / Outlet Valve Rear Left
• 36 Inlet Valve Rear Right
• 37 Front Right Wheel Speed Sensor
• 40 Rear Output Valve
• 49 Power Supply Solenoids
• 50 Throttle Valve Mechanical Fault
• 56 ASC Separator Valve Fault
• 65 ASC Computer Fault
• 66 DME RPM signal Fault
• 68 Control Unit Defect
• 72 Internal Fault
• 81 Speed Sensor Front Left Connection
• 82 Speed Sensor Front Right Connection
• 84 Speed Sensor Rear Left Connection
• 88 Speed Sensor Rear Right Connection
• 97 Speed Signal Front Left
• 98 Speed Signal Front Right
• 100 Speed Signal Rear Left
• 104 Speed Signal Rear Right
• 113 Speed Information Front Left
• 114 Speed Information Front Right
• 116 Speed Information Rear Left
• 120 Speed Information Rear Right
• 129 DME Connection
• 130 TPS
• 132 Brake Pedal Travel Sensor
• 133 Valve Power Supply too High
• 136 Brake Hydraulics -Quality
• 145 Hydro Pump Failure
• 146 Coding Faulty
• 148 Motor Temperature over CAN bus
• 152 Brake Pedal Travel Sensor -Hydraulics
• 161 Outlet Valve Front Left or Front Left Wheel Sensor
• 162 Outlet Valve Front Right or Front Right Wheel Sensor
• 164 Rear Left Output Valve or Rear Left Wheel Sensor
• 168 Rear Right Output Valve or Rear Right Wheel Sensor
• 177 Valve Power Failure
• 184 CAN ERROR
• 193 DME Ignition Signal
• 255 Accumulator Fault
ABS 3
• 5D90 Left Front Wheel Speed Sensor : Accident Recognition
• 5D91 Left Front Wheel Speed Sensor : Extrapolation
• 5D92 Left Front Wheel Speed Sensor : Periodical Control
• 5D93 Left Front Wheel Speed Sensor : Accident Recognition
• 5D94 Left Front Wheel Speed Sensor : Long Term Control
• 5DA0 Right Front Wheel Speed Sensor : Accident Recognition
• 5DA1 Right Front Wheel Speed Sensor : Extrapolation
• 5DA2 Right Front Wheel Speed Sensor : Periodical Control
• 5DA3 Right Front Wheel Speed Sensor : Accident Recognition
• 5DA4 Right Front Wheel Speed Sensor : Long Term Control
• 5DB0 Left Rear Wheel Speed Sensor : Accident Recognition
• 5DB1 Left Rear Wheel Speed Sensor : Extrapolation
• 5DB2 Left Rear Wheel Speed Sensor : Periodical Control
• 5DB3 Left Rear Wheel Speed Sensor : Accident Recognition
• 5DB4 Left Rear Wheel Speed Sensor : Long Term Control
• 5DC0 Right Rear Wheel Speed Sensor : Accident Recognition
• 5DC1 Right Rear Wheel Speed Sensor : Extrapolation
• 5DC2 Right Rear Wheel Speed Sensor : Periodical Control
• 5DC3 Right Rear Wheel Speed Sensor : Accident Recognition
• 5DC4 Right Rear Wheel Speed Sensor : Long Term Control
• 5DF0 Pump Motor
• 5DF2 Internal Error, Valve/ECU Hardware Error, ROM/RAM Check
• 5DF4 Power Supply too Low
• 5DF5 Control Unit Internal Error
• 5DF7 Power Supply too High
• 5E00 Tyre Test Active
• 5E01 Tyre Test Timeout
• 5E02 Tyre Test Gyration Sensor Justification Error
• 5E03 Tyre Test Gyration Sensor Error
• 5E04 Tyre Test Lateral Acceleration Sensor Error
• 5E05 Tyre test Lateral Acceleration Sensor Error and Gyration Sensor
• 5E06 Tyre Test Gyration Sensor Fault
• 5E07 Tyre Test Lateral Acceleration Sensor Error and Gyration Sensor Fault
• 5E08 Tyre Test Steering Angle Sensor Error
• 5E11 Internal Error CAN-Controller
• 5E14 CAN Timeout DME/DDE
• 5E15 CAN Timeout EGS
• 5E16 CAN Timeout Instrument Cluster
• 5E18 CAN DME/DDE Message
• 5E19 CAN DME/DDE Torque Reduction Not Possible
• 5E1A CAN DME/DDE Signal Error
• 5E1E CAN Timeout LWS
• 5E1F Steering Angle Sensor - not Initialised
• 5E59 Coding Error
• 5E5B Switch Pressed Longer than 10s or Faulty
• 5E5D Brake Fluid Level Switch
• 5E5E Brake Light Switch
• 5E20 Pressure Sensor 1 Accident Recognition
• 5E21 Pressure Sensor 2 Accident Recognition
• 5E24 Pressure Sensor 1/2 not Plausible
• 5E26 Sensor Power Supply
• 5E2F Temperature Sensor
• 5E30 Lateral Acceleration Sensor Accident Recognition
• 5E32 Lateral Acceleration Signal not Plausible
• 5E38 Wheel Speed Sensor Accident Recognition
• 5E3C Wheel Speed not Plausible
• 5E40 Lateral Acceleration Signal not Plausible, Offset
• 5E43 Lateral Acceleration Internal Error
• 5E4E DSC Sensor Offset Check
• 5E4F Long Time Regulation DSC
